help again pleas? (how can I get better gas mileage and what about 'the tornado')
Old 10-14-05, 12:16 PM
donktan
donktan's Avatar
Default help again pleas? (how can I get better gas mileage and what about 'the tornado')
anyones know how i can get better gas milleage? i already got my fuel injectors cleaned new gas fileter, and new air fileter in. waht about that tornado thing anyone use that thing?
and my left light has sun damage anyone know how i can take that off someone told me to use 2000 grid sand paper any suggestions? THANKS EVERYONE!
Old 10-14-05, 12:23 PM
Cloud9
Cloud9's Avatar
what's your current gas mileage? do a search and you can find some pointers
replace spark plus, ditributor, distributor cap, seafoam, proper air pressure in the tire. tornado thing is a hoax.
Old 10-14-05, 12:27 PM
VJ RC51
VJ RC51's Avatar
if u can stand the semi truck noise, remove the two outter mufflers, 2-3mpg instantly
Old 10-14-05, 01:17 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
donktan,
Please try to use a descriptive title like "how can I get better mileage". It helps members decide whether they might have something to contribute to your question. Many will just ignore one the way you have it titled (I updated it for you this time).
Here's a thread you should read that pretty much covers a wide gambit of additional things you can do to get better mileage:
https://www.clublexus.com/forums/sho...d.php?t=177157
Ignore the tornado and turbinator things, it's a hoax. There are lots of threads about it if you use search feature of our forum.
Lots of crap out there like the turbinator and 'tornado'
https://www.clublexus.com/forums/sho...hlight=tornado
https://www.clublexus.com/forums/sho...ght=turbonator
Old 10-14-05, 01:25 PM
pilip99
pilip99's Avatar
in a nutshell the tornado is a scam
Old 10-14-05, 01:26 PM
pilip99
pilip99's Avatar
if you want a better mpg mod why not do the bfi?? run a search on bfi and you will run into these threads hope this helps
Old 10-14-05, 01:39 PM
soarer1023
soarer1023's Avatar
well i did that trick, took the stock mufflers out and just running on straight pipes, i do notice a little better mpg, but i don't think 2-3 mpg increase, and on top of that, i don't really think it sounds like a semi truck, but it depends on what u put on afterward, and spark plugs is a must as well.
i did quite a few changes over the summer break. i changed my spark plugs, radiator fluid, and took out my stock mufflers, and everything little things adds up, and all that it did made a difference, especially on the freeways, like starting from a full tank going highway 5, be4 i did the changes, i got 190miles at half way mark. but with the changes, it got up to about 210 half way, and i travel at around 80-85mph(no A/C), and that's like a galon right there, but that's on the freeway. in the city, i don't get much out of it, even tho it is still better than be4.
do oil change regularly, get alignment, good tires, check everything nice and clean, and u will know the difference.
edupim
RX - 1st Gen (1999-2003)
04-24-14 04:25 PM
MoJoMan
31
08-15-11 10:06 PM
AD_SC3
03-09-09 09:49 PM
TommyT
06-21-08 07:34 PM
SC3005SPD1
Performance & Maintenance
06-23-05 07:21 PM
Quick Reply: help again pleas? (how can I get better gas mileage and what about 'the tornado')
