rev limiter (help)
Old 06-02-01, 12:17 PM
Tony Brady
Tony Brady's Avatar
has anyone disabled the rev limiter on the IS200, does it work? is it ok for the engine? will it improve performance?
Old 06-05-01, 11:20 AM
UK_GS300
UK_GS300's Avatar
Unless you have modified the engine to produce more power at higher rpm then there is no point.
The engine produces it's maximum bhp before the redline and then starts to tail off. If you increase the rpm limit you will be producing less and less power. Also running the engine above the rev limit will wear your engine much faster.
The IS200 engine peak bhp is at 6,200 rpm. Change just after so that you stay near the peak power in the next gear.
Hoovey689
06-07-19 08:57 AM
goldenrod
Performance & Maintenance
03-15-18 04:54 PM
PhiDeltBee
IS F (2008-2014)
24
09-16-12 02:43 AM
Lex5150
12-26-07 05:49 PM
Quick Reply: rev limiter (help)
