What grade gasoline do you use in ~your~ Lexus?
Old 04-18-04, 07:46 AM
Threxx
Threxx's Avatar
Originally posted by EDGE2
The owners manual says 87 is fine added performance with premium, the only lexus vehicle that the owners manual says to use premium is the IS300, have not really read any others, it says use premium and if you have to use a lower octane just take it easy with the car till you can get some 93
I use whatever the owners manual suggest, but Im also not into this whole cause it's a Lexus you got to use Premium
I'm not 100% sure about other Lexus vehicles since I haven't had that much-hands on research and experience with them, but what I do know is:
My father just cross-shopped between a 2004 Camry V6 and a 2004 ES330, he was specifically told by both Toyota/Lexus, the dealerships, and the documentation he read from both cars that he would be required to use premium gas in both the Camry V6 and the ES330. After the dealerships realized that he didn't appreciate this fact, they told him that if he used 87 it would still 'run' (because of the knock sensor retarding the timing), but he would have a little bit of reduced performance and worse gas milage (which defeats the purpose of saving 20 cents per gallon in the first place). Only the Camry 4-cylinder recommends 87 Octane.
Furthermore, when I go to put gas in my 99 GS400, the fuel filler door itself specifically states to only use 91 Octane and above.
As for the using a lower octane gas will shorten the life of an engine designed for higher octane, my friends father drives a 98 maxima with 180k on it the car requires premium, car drives like new cause he does all the maintenance and it's a city car so it gets driven hard, maybe the engine life has been shortened to 250k
I had a 95 Maxima (they remained unchanged in almost all regards, especially the powertrain, from 95 until 99) and the owners manual specifically stated that 87 octane was recommended. So I'm not sure why your friends father thought he should be using premium, because it was not stated in the owner's manual or anywhere by Nissan. Unless he was having problems with predetonation caused by carbon build up (which results in a higher compression ratio in the cylinder) of his higher milage engine... he really shouldn't have been using 93 octane for any reason.
Old 04-18-04, 03:29 PM
<VENOM>
<VENOM>'s Avatar
The Lexus your father was cross shopping with the Camry was the ES330(225hp), I have the ES300(210hp) and it has no premium required sticker, was he looking at an XLE cause those have the 210hp but the SE is the only model with th 225hp motor.
The 98 maxima runs on 87 he don't put 93 in it, the newer maximas or atleast the VQ engines vary from year to year on the use of premium or not, guess Nissan changed to better suit the needs of people who just use 87.
edit:
just checked my owners manual, select octane rating 87 or higher for added performance
Old 04-18-04, 08:45 PM
HarrierAWD
HarrierAWD's Avatar
Originally posted by HarrierAWD
The ES V6 and the Camry V6 are tuned differently. The ES V6 makes 210 HPs (or more now), the Camry V6 is tuned for 192 HPs on regular fuel. Putting 87 in ES V6 probably won't damage the engine short-term, it'll just give less performance.
Updating my own post.
The Consumer Reports tested the new ES330 (225 hp) recently. It specifies regular gas in the review.
Checked with my friend who owns a 2002 Camry LE V6. He said it uses regular gas.
Old 04-18-04, 10:00 PM
nthach
nthach's Avatar
91 octane, with a shot of Red Line Oil SI-1, since i use the cheap stuff now(Costco or Arco usually)
Old 04-14-06, 04:32 PM
dotbowels
dotbowels's Avatar
Default 2003 ES330 Says Premium but ..........
Service guy told me okay to use 87 as long as there isnt a ping. He said the Toyota engine which is virtually the same V6 calls for 87. He said it won't void warranty.
pierpark
GX - 2nd Gen (2010-2023)
553
12-12-23 07:12 AM
Kbach
GX - 1st Gen (2004-2009)
388
11-30-20 03:05 AM
skeoripper
05-27-07 12:34 PM
Dx3
SC- 1st Gen (1992-2000)
107
04-23-04 01:01 PM
JohnnySC
34
02-11-02 02:31 AM
Quick Reply: What grade gasoline do you use in ~your~ Lexus?
