Trunk opening issues.....
Old 11-15-14, 06:01 AM
MrMark
MrMark's Avatar
Default Trunk opening issues.....
My trunk will open with the FOB and cabin switch.......it will start to open, then reach about 2/3 open and then stops and closes hard. I have a custom interior panel that may be too much weight for the lid, but even when I assist it going up, it still stops and closes hard.
Is there a way to either manually override the auto open/close, or change the sensitivity of the auto close actuator?
Old 11-15-14, 06:08 AM
roadfrog
roadfrog's Avatar
To clarify, do yo have the motorized hydraulic trunk (with a switch on the trunk lid)?
If NOT.....then yes you can adjust it. I can tell you how, as I have done it. I'll post how once we establish what you have.
Old 11-15-14, 12:58 PM
JiffyPop
JiffyPop's Avatar
I just made a diy how to fix this.
https://www.clublexus.com/forums/ls460-ls460l-and-ls600h/763181-diy-adjusting-trunk-torsion-tension.html
Old 11-16-14, 05:50 AM
MrMark
MrMark's Avatar
Motorized....
Old 11-19-14, 12:14 AM
Shibumi1
Shibumi1's Avatar
1st try removing the custom decklid piece an see if the trunk functions as normal... if so u can try adding gas shocks.. i also think there maybe an adjustment for the torsion bars that support the trunk lid... worst case u can disconnect the trunk motor an just use the gas shocks to lift an hold the trunk open...
peasodos
02-15-17 08:16 AM
roadfrog
03-18-14 06:50 AM
Z0SICK
01-19-14 12:44 PM
sgani
08-04-12 04:47 PM
memasterac
03-11-10 09:01 AM
Quick Reply: Trunk opening issues.....
