LS460/600 bluetooth music streaming
There are several threads about this. I bought the set up and have used it for a year with very good sound and reliability. There are about three pieces to purchase including a noise suppressor that is very easy to install. I don't remember the parts for it but there is a very good thread that should be able to be searched.
Ogun360 (09-07-21)
http://www.newpotatotech.com/TUNELIN...k_android.html
There is also a version for iPhone. Can also stream via FM and there is a usb charge so you don't completely loose a 12v socket.
Amazon.com: VicTsing Portable USB Bluetooth Audio Music Streaming Receiver Adapter with 3.5 mm Stereo Output Black: Computers & Accessories
Amazon.com: PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator Works with iPod/Zune/iRiver and Others: Automotive
any usb car charger will enable anyone to stream music into the aux input on the ls460.
specific question about bluetooth streaming
Regarding the VAIS SL3B... I've read the website's installation manual and the various threads on this website and need to double check something. The manual seems to suggest that once the unit is installed, you hit the CD-Aux button twice to select the SL3B. Since that is typically how you select the Aux port (in the center console), I'm wondering Does this mean that the SL3B has taken the place of the Aux port and that the Aux port no longer works?
If you have this unit installed, please tell me, can you still use the Aux port in the center console if you want?
-V
PS, I have a 2009 LS460 with stock stereo.
-V
Last edited by vnicholes; 05-04-15 at 09:42 PM. Reason: adding info (model/stereo)
-V
-V
Lexus ls600hL 2008
I was intrigued by this USB! Isolator loop solution rather than spending several hundred on, say, the Vais SL3b-L system.
Can anybody please give me a steer as to what my options are today in 2021 in terms of Bluetooth receivers etc, versus this old thread here?
I'm a but clueless with thus sort of thing!
jmaynard
12
06-17-11 09:15 AM
TorontoIS
03-02-08 07:33 PM
