Headlight Levelling
Headlight Levelling
Hello,
I have a 2003 LS430 and I'm getting the "Headlight Levelling" warning. Is there any way I can troubleshoot this without replacing the sensors (they're not cheap). I know I can pull the fuse and have it go away, but if I did want to narrow down which one it is, can I somehow pul the error code from the car without going to the Lexus dealer?
Thanks.
Thanks.
http://www.obdinnovations.com/vgate-...r-white-black/
I also see this one here:
http://www.obdinnovations.com/memosc...xus-scan-tool/
More expensive, but seems to have a lot of functions comparable with the techstream. Have you tried it?
I see you are in Canada - the northern climates take a toll on this exposed mechanical sensor. Once you identify which sensor (front or rear) you can try removing it and placing it in a rust remover solvent (like CLR) to remove the rust around the switch joint (it's a mechanical arm). This may solve the problem, at least temporarily, as it did for me. Once you've removed the rust, rinsed and dried the arm sensor, place some grease around the area where the arm rotates up/down. This may delay further rust in the area where the part fails.
Is there any way to identify which sensor is causing the problem - i.e. front or rear? The manual is a little thin on details on troubleshooting the sensors themselves. I guess it is basically a resistor, but I don't know what the acceptable range of resistance is. If you have any details that would help a lot.
Thanks.
I don't have a way to identify which one it is. NOTE: the only area of rust that is of concern is in the arm swivel joint. It gets tight and doesn't swivel easily preventing the sensor arm from moving up/down based upon weight in the car and doing a self-test on start-up.
Edit: I checked my records and I ended up having to buy the rear sensor: # 89408-50060 It makes sense that it's the rear sensor since the weight in the rear elevates the headlights which the sensor detects and lowers the headlight aim to compensate.
I think I found the thread. Is this the unit you are talking about?
No I haven't tried the 2nd tool you mentioned, but it looks nice
As for the first one, yes that is the one I use. And I use it with the software mentioned in the post, iPhone app.
Good luck solving your troubles.
topperdogg
08-13-17 01:32 PM
