Replacing Drivers Side Mirror: How to or Advice Needed
Old 04-01-15, 03:50 PM
bmore430
bmore430's Avatar
Default Replacing Drivers Side Mirror: How to or Advice Needed
Drivers Side Mirror has been acting up and sadly it's not the switch. I did the cleaning and no help. Passenger side works perfectly. The up and down tilt feature is no longer working so I think the internal motors are burnt out. They will work for a minute or two if you push on the mirror to assist them but that's about it. It's driving me crazy so I need to decide a plan of action.
1. Buy a whole new mirror assembly? Anyone know best source for new unit or discount code? I see sewell is no longer with us. I'm sure this option will be expensive.
2. Can the motors that control the mirror up and down movement be replaced? Is there a how to? Part numbers etc.
I think this is a common problem once these cars age a bit. I plan to keep her awhile so I like things working as new.
Old 07-01-15, 11:12 AM
bmore430
bmore430's Avatar
Bumping this to the top. Any input on this guys? I cant be the first one to have to replace one of these mirrors.
Old 07-01-15, 11:35 AM
Tom57
Tom57's Avatar
I've not had this issue, but I've seen existing thread(s) > I believe the motors are replaceable.
Old 07-01-15, 12:18 PM
LiCelsior
Retired
LiCelsior's Avatar
https://www.clublexus.com/forums/ls4...iy-thread.html
look under electrical section, your answer is in there.
always look in the FAQ thread and search before making a new thread.
Old 07-01-15, 12:35 PM
bmore430
bmore430's Avatar
Thank you. I saw the mirror dissection thread for the new motors but id rather go new at this point as i think install and downtime would be shorter. If I get a new mirror then I may take apart the old one and rebuild it and keep or sell it.
Old 07-01-15, 12:38 PM
bmore430
bmore430's Avatar
I'm not new here I"ve seen all those threads. None of them involved replacing the whole mirror assembly. It is not a power folding problem or a dirty switch, Thanks
Old 07-01-15, 01:08 PM
LiCelsior
Retired
LiCelsior's Avatar
you can remove the little cap thats behind the mirror, should be either 3/4 bolts holding it in. then just unclip the connector and the mirror is out.
mwswindell
GX - 1st Gen (2003-2009)
07-04-17 07:20 AM
ThumperPup
ES - 5th Gen (2007-2012)
06-12-17 12:55 PM
varcity64
01-28-16 06:57 AM
grsams
LX - 3rd Gen (2008-2021)
01-06-15 06:15 PM
DarkknessD
09-05-10 08:34 AM
Quick Reply: Replacing Drivers Side Mirror: How to or Advice Needed
