Shift boot help.....but in japanese.
Old 02-17-15, 01:47 AM
bfg23
bfg23's Avatar
Default Shift boot help.....but in japanese.
Hey all, I bought one of the shift boots below and am having trouble figuring out what step 3 details, particularly, the little bit in the bubble.
It came with half a dozen small foam sticky strips i assume are used somewhere.
If anyone can read japanese and can translate it would be much appreciated.
Old 02-28-15, 04:56 PM
jpv7774
jpv7774's Avatar
well I dont speak Japanese but I did just take my console apart and I think I recognize the part in the bubble.......once u remove heated seat wood console panel....then shift ****.......then remove chrome trim......then remove wood console panel that surrounds the shifter. Well at this point they ask u to remove the gear shift indicator the grey piece.....unclip the visible 4 clips and pull up.......the trick is there is a wire attached. The wire goes to a clear plastic piece that is snapped under the grey piece....this clear plastic piece has a light attached as well. I believe the clear plastic piece is the piece in the bubble........Being that u are installing a shift boot I assume they just want u to remove it. I will enclose picsShift boot help.....but in japanese.-l1-resize.jpg
BigEarl
RC - 1st Gen (2015-present)
12-14-17 07:52 PM
otcviper
09-30-11 11:07 AM
sliva001
SC- 1st Gen (1992-2000)
11-02-06 07:54 PM
flyhigh123
Performance & Maintenance
03-18-05 04:57 AM
Arun
GS - 1st Gen (1993-1997)
04-30-03 06:07 PM
Quick Reply: Shift boot help.....but in japanese.
