window express reset?
Old 01-04-15, 08:52 AM
cooperww
cooperww's Avatar
Default window express reset?
Good morning! My right front window goes all the way up in express mode then kicks back down about halfway. I understand that there is a sequence to reset the window memory. Has anyone had same issue and if so how was issue resolved? The window operates fine except for the express up.
2004 LS430 Ultimate
Old 01-04-15, 09:01 AM
Tom57
Tom57's Avatar
Try rolling window down about 3/4. Then hold the window control button in roll up position for about 10 seconds (continue holding after window has rolled up completely). If that doesn't work, reverse the sequence. 1/4 window down, then hold control button for 10 seconds in down position.
Old 01-04-15, 09:07 AM
cooperww
cooperww's Avatar
Okie dokie. Will give it a try right now. TY
Old 01-04-15, 09:17 AM
cooperww
cooperww's Avatar
Did not work. I hear a beep in the rf door when I use the window switch. The window express setting just stopped working for no apparent reason. The beep seems to be coming from either the control module or glass regulator.
Old 01-04-15, 09:18 AM
cooperww
cooperww's Avatar
Actually more like a chirp.
Old 01-04-15, 09:45 AM
Tom57
Tom57's Avatar
It may be a bad switch or ... ? Does it work in the normal (nor express) position up and down? You may want to try taking the switch out disconnecting it, then re-connecting it. Very easy. Use tape on tip of screwdriver to pry switch panel up at rear of switch.
Old 01-04-15, 10:12 AM
Tom57
Tom57's Avatar
There are several CL threads on this. Here's one: https://www.clublexus.com/forums/gs-...ow-switch.html
Old 01-04-15, 03:40 PM
Lavrishevo
Lavrishevo's Avatar
I had the opposite with my back seat passenger side window. Only auto worked at that seat. The switch is very easy to remove and take apart. Mine had a little plastic clip broken which was preventing button from rocking across the contacts properly. A little super glue and 2 hours later she is working like new. Saves about $75 for a new switch.
Old 01-04-15, 08:16 PM
Tom57
Tom57's Avatar
The complete switch assembly is widely available used for $75 or so. You can easily swap your wood grain switch surround onto the replacement part.
http://www.ebay.com/itm/01-06-Lexus-LS430-Driver-Master-Window-Switch-OEM-/361157027928?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ALS430&hash=item5416a2e858&vxp=mtr
Old 01-05-15, 08:02 AM
Lavrishevo
Lavrishevo's Avatar
That is cheap for the drivers master. The individual switch is about $70 new. You don't need the wood or assembly. Switch just pops out and you can replace or fix. They are very easy to disassemble and fix as I mentioned.
http://www.lexussouthatlantaparts.co...403050050.html
Old 01-05-15, 08:17 AM
Tom57
Tom57's Avatar
Follow steps 3 & 4 in this link (do not remove the screw shown in step 4) to remove the old switch assembly: http://www.lexls.com/tutorials/body/fdoorpanel.html.
Old 11-09-18, 08:37 AM
jimisbell
jimisbell's Avatar
Where do you find stuff like this? Its not in my manual !
Old 11-10-18, 08:16 AM
StanVanDam
StanVanDam's Avatar
Official 2003.7 and older LS430 Power Window Initialization
Official 2003.8 and newer LS430 Power Window Initialization
simplecar
RX - 1st Gen (1999-2003)
09-15-18 07:43 PM
beachit321
02-28-18 06:54 PM
UDel
09-03-16 02:07 PM
Leines
05-08-12 01:22 AM
Quick Reply: window express reset?
