torque specs for front/rear suspension
Old 07-11-14, 10:52 AM
choi0706
choi0706's Avatar
Default torque specs for front/rear suspension
does anyone have the torque specs for the front and rear suspension? specifically everything that relates to the strut.
Old 07-11-14, 11:43 AM
rkw77080
rkw77080's Avatar
Default Shock/Strut torque specs - 2004 LS430
You didn't mention model year. Here are torque specs for 2004 LS430:
Front Struts:
Top strut mount (3 nuts): 58 N.m (43 ft.lbf)
Top strut lock nut: 28 N.m (20 ft.lbf)
Bottom nut: 157 N.m (116 ft.lbf)
Rear Struts:
Top strut mount (3 nuts): 64 N.m (47 ft.lbf)
Top strut lock nut: 27 N.m (20 ft.lbf)
Top strut mount cap (3 nuts): 25 N.m (18 ft.lbf)
Bottom nut: 70 N.m (52 ft.lbf)
I have the shop repair manual for 2004 LS430 , so please let me know if you need other specs for this model year.
Old 07-11-14, 12:41 PM
choi0706
choi0706's Avatar
is there bump stops on the oem strut top? for the fronts
Old 07-12-14, 10:17 AM
alanchad
alanchad's Avatar
Default bump stops
Yes.
Go to sewell lexus parts and you can see diagrams and parts/parts numbers for all this.
Alan
Old 07-17-14, 11:04 AM
choi0706
choi0706's Avatar
Originally Posted by alanchad
Yes.
Alan
It doesnt really show a front bump stop.. but ive figured it out..
now on the rear the cap above the strut mount, curious on why its got a different torque spec.. It appears to be a large washer between the chassis and strut mount..
Old 07-21-14, 04:10 AM
rkw77080
rkw77080's Avatar
Here's a picture showing the strut lock nut that holds down the large washer (torque to 20 ft-lbf), the 3 strut top mount bolts that hold the strut/spring assembly to the car (torque to 47 ft-lbf), and the strut mount cap with rubber seal (torque to 18 ft-lbf).
Attached Thumbnails torque specs for front/rear suspension-torque.jpg
Svulexus
05-03-18 04:04 PM
shajbot
Suspension and Brakes
09-27-17 10:07 PM
jwigley
RX - 1st Gen (1999-2003)
18
03-15-16 02:12 PM
ahornick
11-12-14 10:43 AM
azednalcm
03-02-09 05:53 PM
Quick Reply: torque specs for front/rear suspension
