04 LS430 smart key problem
Hey everyone..
Long story short, my battery took a dump yesterday. Got it charged and it's back in the car. Only problem now is that the smart key doesn't work anymore.
I cannot lock/unlock the car. Also I could only fire up the car with the key in the ignition. Without the key, it tells me " keys not detected, ". I have also double checked the battery on the remote as well as the smart key disable/enable function located on the bottom of the dash.
I tired searching but no luck.. Anybody can lmk thanks!!!
Under your steering wheel (if you haven't seen it before, stick you head under) there are two buttons.
1. for TPS reset
2. to acticate your smart key.
Try that.
Good Luck!
1. for TPS reset
Try that.
Good Luck!
I ran into the same problem on my s500 . I believe you must have the key in the ignition and hold the lock button contiously until all door unlock . This is the initialze procedure that most factory used when a battery goes out on the key ,it also was the same for my e38 740 hope this help ..
on safecar.gov (NHTSA) there's an entry for the 2004 LS
Not sure if it would be helpful or not since I can't actually see the TSB. Maybe your dealer could tell you.
Service Bulletin No.: 00304
Component(s): EQUIPMENT
NHTSA ID Number: 10008399
All Products Associated with this Service Bulletin
Vehicle MakeModelModel Year(s)
LEXUSLS 4302004
Details
0 Associated Documents
Manufacturer: TOYOTA MOTOR CORPORATION
SUMMARY:
REPAIR MANUAL SUPPLEMENT:SMART KEY REGISTRATION. *MJ
LEXUSLS 4302004
Details
SUMMARY:
mikevanle
11-29-23 07:24 PM
