Door Lock Actuator - is this the correct part
Old 10-20-10, 09:08 PM
bigcory
bigcory's Avatar
Default Door Lock Actuator - is this the correct part
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
Its the drivers side front door, 2005, is this the correct part?
Old 10-22-10, 11:48 AM
bigcory
bigcory's Avatar
any help from someone that has done this?
I need the part number for the drivers side, front door, lock acutator
Old 10-28-10, 09:42 AM
buggs384
buggs384's Avatar
cory,
that look like it...but really if your going in that deep wh ynot just buy the maguchi motor for lile 10.00 and replace the motor?
Since your doing it yourself its not hard just opening the housing and replacing the motor.
https://www.clublexus.com/forums/gs-...ators-diy.html
Here is the write up i followed. It was almost dead on...but this will give you the road map if you plan on doing this your self. Mine was done a year ago and I have had zero problems.
Old 10-28-10, 09:54 PM
VQT
VQT's Avatar
Buggs,
Did you have to take the window out to get the actuator out?
Thanks,
VQT
Originally Posted by buggs384
cory,
Old 10-29-10, 02:08 PM
buggs384
buggs384's Avatar
No, I did not take the window out...just rolled it up all the way.
Old 11-01-10, 10:39 AM
bigcory
bigcory's Avatar
To be honest I would rather spend $10 bucks. : )
My main issue is that there seems to be a bit of confusion on which is the correct replacement motor. I want to make sure i'm putting the motor with the correct torque and power figures in. Some of the motors also need to be modified because the shaft is not D shaped.
All that sounds like a head ache to me.....
Old 11-02-10, 08:27 AM
buggs384
buggs384's Avatar
I can send you the part number....The only modification i did was to make a flat spot on the rounded shaft ot the motor...i just used a grin ding wheel and took my time checking fit every so often...took no more than 3 mins to grind and check for fit
Old 11-02-10, 09:06 AM
Jabberwock
Jabberwock's Avatar
You could also use an inexpensive Dremel tool to grind the flat spot
Old 11-20-10, 09:35 PM
bigcory
bigcory's Avatar
yeah that would be cool, whats the part number? Did anyone check to see if the motors were a match?
Riemy6
09-18-16 10:18 AM
TTurboPimp
02-15-14 02:54 PM
srgone
08-23-11 10:05 AM
fblonk
11-04-09 08:45 PM
Quick Reply: Door Lock Actuator - is this the correct part
