How to change the cabin air filter in a 91 Lexus?
Old 04-11-15, 04:40 PM
LexusGuy91
LexusGuy91's Avatar
Default How to change the cabin air filter in a 91 Lexus?
Hi
How can I change the cabin air filter in my 91 Lexus? Whenever I turn on the A/C it smells like mold.
I tried looking in my manual but I can't find where it explains how to replace it.
Any help is appreciated
Thanks
Old 04-11-15, 04:41 PM
python
python's Avatar
there isnt 1
Old 04-11-15, 09:32 PM
oldskewel
oldskewel's Avatar
Yes, there is no cabin air filter in the '91. When I used to get a moldy smell, I would do 2 things that seemed to help:
1. with the AC blowing at full speed (car parked), spray Lysol directly into the outside air intakes that are behind the engine and at the bottom of the windshield. This kills things growing in the HVAC system.
2. drive with the heater on max heat for a while. Roll down the windows to regulate heat inside. This cooks things living in the HVAC system.
There is a chance your AC evaporator drain tube is clogged. You should get some condensation dripping on the ground after running the AC. If not, look for the hose and check it.
Old 04-12-15, 05:37 AM
johnnyg66
johnnyg66's Avatar
Try this worked okay for me.
https://www.clublexus.com/forums/ls4...hs-use-it.html
aachowhan
10-13-19 07:53 AM
RealMCR12
RC - 1st Gen (2015-present)
08-09-17 01:13 PM
theazz
09-12-16 02:30 AM
MNRambler
08-02-15 11:05 AM
teefbee
05-15-12 07:00 AM
Quick Reply: How to change the cabin air filter in a 91 Lexus?
