Egr tube woes
Old 05-12-14, 10:40 AM
Ontiveros3
Ontiveros3's Avatar
Default Egr tube woes
I have the common EGR tube leak on my 96 LS. I have found a short tube which I am guessing is the lower one, on ebay. It shows for SC400 SC 400 Soarer 1997 LS400 LS. Will it fit my application. Also which tube is more prone to leaking? I am not 100% sure which one it is. I sure wish these were more accessible.
Thanks.PPO
Old 05-12-14, 11:07 AM
timmy0tool
timmy0tool's Avatar
the common leaky EGR pipe is the lower pipe, pictured in 25601.
i am unsure if the SC400 part will interchange but the lexus part number should be 2560150060.
Old 05-12-14, 11:51 PM
cgawelko
cgawelko's Avatar
bypass it. hose is at least $200 and a ****** to change. Bypass and be done with it forever, or buy a new pipe and put a new one on in 50k.
Old 05-13-14, 03:26 AM
dashan
dashan's Avatar
I replaced mine, and it is a doable job.
https://www.clublexus.com/forums/ls4...-egr-pipe.html
Old 05-13-14, 10:33 AM
timmy0tool
timmy0tool's Avatar
i paid a little over $100 for my tube from sewell with a club lexus discount.
you don't bypass it, you just block it off. i wonder the ramifications in doing so. any CEL?
Old 05-13-14, 02:29 PM
Ontiveros3
Ontiveros3's Avatar
I think I would rather cap it off. But I cant believe its 100 bucks for 2 pieces of basically metal gaskets. bummer.
Old 05-13-14, 04:12 PM
midwest2
midwest2's Avatar
Replaced mine when starter was replaced. It's an easy job at that point.
UNCJD
09-09-15 01:55 PM
dashan
13
10-03-11 08:51 AM
pierce1
01-10-11 09:06 PM
kelley5795
18
01-14-10 08:29 PM
DroppedGS
08-28-06 11:10 AM
Quick Reply: Egr tube woes
