1996 LS400: How to Remove The Infamous EGR Pipe
Old Jun 10, 2013 | 12:18 AM
dashan's Avatar
dashan
Default 1996 LS400: How to Remove The Infamous EGR Pipe
1996 LS400, with 210,xxx miles
1. Remove the Right Cat Converter
2. Loose and disconnect the Rear Joint of left cat converter.
The post-Cat exhaust pipe will drop.
Notes: Don't even bother putting the PB blaster on nuts of the rear joint of Cat Converter if they are original ones and were rusty, and not replaced before. PB blaster will not work. Simply cut the bolt, and punch the bolt out from behind.
Attached Thumbnails 1996 LS400: How to Remove The Infamous EGR Pipe-111.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-112.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-113.jpg
Old Jun 10, 2013 | 12:29 AM
dashan's Avatar
dashan
1. Upper bolt and lower bolt of the upper end of EGR tube. Use combination of a 20-inch-long, 3/8 inch extension bar, a universal joint, and a 6-point, 12mm socket to remove the upper two bolts.
The Broken EGR pipe
Old Jun 10, 2013 | 01:36 AM
dashan's Avatar
dashan
2. Two nuts of the EGR pipe lower end: Use a 12mm wrench to remove two 12mm nuts of the EGR tube lower end, the two nuts are right in front of your eyes.
Broken EGR pipe
Attached Thumbnails 1996 LS400: How to Remove The Infamous EGR Pipe-11.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-12.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-13.jpg
Old Jun 10, 2013 | 01:38 AM
dashan's Avatar
dashan
Tools
1. Universal Joint
2. 12mm 6-point socket
3. 20-inch-long extension bar
4. 3/8 inch rachet
5. 3/8 inch breaker bar
Attached Thumbnails 1996 LS400: How to Remove The Infamous EGR Pipe-15.jpg
Old Jun 10, 2013 | 10:47 AM
timmy0tool's Avatar
timmy0tool
thank you for this! PB blaster is always your friend when working with exhaust bolts. i have yet to do this but the pictures still don't give me that much confidence. i suppose i have to get under there and actually do it. now to find a 20" extender!
where is the other half of the pipe? did you replace with an OEM part or fix the old one?
Old Jun 10, 2013 | 01:46 PM
dashan's Avatar
dashan
New EGR pipe
Old Jun 10, 2013 | 01:48 PM
dashan's Avatar
dashan
New gaskets for Cat Converter front joint and rear joint, respectively.
Attached Thumbnails 1996 LS400: How to Remove The Infamous EGR Pipe-15.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-14.jpg
Old Jun 11, 2013 | 04:54 AM
billydpowe's Avatar
billydpowe
Excellent write up, you covered all the basic's....
Old Jun 11, 2013 | 11:48 AM
timmy0tool's Avatar
timmy0tool
doesn't the pipe have gaskets on them as well? reused the old ones?
Old Jun 11, 2013 | 01:26 PM
LScowboyLS's Avatar
LScowboyLS
did you use stainless steel bolts where the rusted ones were (to save yourself next time?)
Old Jun 11, 2013 | 02:36 PM
dashan's Avatar
dashan
Use New ones
Old Jun 11, 2013 | 02:37 PM
dashan's Avatar
dashan
No SS bolts.
Old Jun 11, 2013 | 02:46 PM
dashan's Avatar
dashan
This is how the rear joint nuts and bolts were removed.
Attached Thumbnails 1996 LS400: How to Remove The Infamous EGR Pipe-111.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-112.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-113.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-114.jpg   1996 LS400: How to Remove The Infamous EGR Pipe-116.jpg
Old Jun 11, 2013 | 03:23 PM
timmy0tool's Avatar
timmy0tool
even with PB blaster you still needed to torch it off, wow it must have been stuck!
off topic, is that your power wire for your aftermarket amplifier running under the car like that? the wire ran that way is susceptible to being scrapped from the pavement especially when lowered. here is a better option if you wish (check out the first few pictures):
https://www.clublexus.com/forums/ls4...tup-ucf20.html
Old May 27, 2017 | 03:36 PM
dashan's Avatar
dashan
Just checked the pipe. Still good.
Bullochdaw
Jul 18, 2018 04:54 PM
jakob27990
May 25, 2017 05:20 AM
dashan
Jun 8, 2013 07:19 PM
rolo1985
Feb 13, 2013 05:57 AM
deanbrown
Jun 26, 2011 07:52 PM
