Pls help! 93 ls400 fuel issues!
Old 05-22-14, 11:08 AM
mk2supra
mk2supra's Avatar
Changed plugs. Nothing yet not even with spray bottle. Damper screw on rail is pushed up but still no legit pressure test. Its firing but Acting like its not firing any way to hand check timing? Maybe it jumped when i drove it for that little bit. idk grasping straws lol
Old 05-24-14, 09:44 AM
mk2supra
mk2supra's Avatar
After further inspection the passenger side
timing is somehow off by about 4 teeth counter clockwise of the marks. Id upload pic but only have a older phone so can't. The repair print up i got said it is interference but ive heard otherwise for vast majority since its Early model. Anyone know for sure?
Old 05-24-14, 09:50 AM
python
python's Avatar
non interference
Old 05-24-14, 10:40 AM
Gene01
Gene01's Avatar
All LS400s (at least US market, and almost certainly in non-US although the model years are slightly different):
90 - 94 are non-interference
95 - 00 are interference
Old 05-25-14, 12:39 AM
mk2supra
mk2supra's Avatar
Thanks. Work will begin tomorrow. Idk how it got from my initial issue to now or if it was just a series of unrelated events but guess its time to find out lol
Old 05-25-14, 08:33 AM
python
python's Avatar
should throw code 13..no rpm signal
Old 05-25-14, 08:40 PM
mk2supra
mk2supra's Avatar
I check for codes after installing And trying my reman ecu but Dont think i got anything ill try again tomorrow but Im almost 100% its off by bout 4 teeth. As of how, as it seemed to happen outta no where, i have no idea
Old 05-27-14, 04:26 AM
mk2supra
mk2supra's Avatar
Not sure why but check engine light isn't illuminating. It was up till yesterday some of the motor is apart in re-timing process. Maybe that's why? But unable to verify codes at this point As my dash is acting up. Background light not on and tach needle is dark too
Old 05-27-14, 07:40 AM
python
python's Avatar
u have the engine apart...why is the battery even hooked up?
Old 05-28-14, 08:36 AM
mk2supra
mk2supra's Avatar
It was mostly covers off nothing major at the time i checked. But i timed it to what i thought was perfect and it runs but kinda "diesels" which leads me to think Im just barely off now. Idk how i could swear all marks were right but hell its running\getting there.
Old 05-28-14, 11:44 AM
mk2supra
mk2supra's Avatar
Re-timed it. Seemed to be a few degrees off at crank. Reassembling to try it again
Old 06-04-14, 09:25 AM
mk2supra
mk2supra's Avatar
The timing seemed to have been a bad tensioner. Update: starts and runs smooth at first then motor slowly starts shaking while idling then stalls out like its starving. i get code 47 for bad sub tps. What are symptoms for that code? And any new insight now that I've cleared some of the water?
GenericUse
28
08-28-22 01:57 PM
89mk398ls4
08-25-18 04:55 PM
klepto2
Performance & Maintenance
12-04-09 03:36 PM
xsc2003
12-12-08 08:16 AM
xsahowx
13
10-27-08 09:20 PM
Quick Reply: Pls help! 93 ls400 fuel issues!
