Exhaust smell in the cabin ('90 LS400, 160k)
I used to have the "check engine" light on intermittently for months now. A few weeks ago, I replaced the EGR modulator (cleaning it did nothing), and the light never came back on. Also, my MPG improved a bit.
However, now for a few days in a row, I have been feeling some exhaust smell in the car, even if I put the vents on "recirculate". What would be the most likely culprit - EGR pipe probably? I don't have the "check engine" light on, and I thought it would come on if the pipe broke... Since I have not replaced my engine mounts yet even though I have the OEMs sitting right here, (too much to do, too little time), I suspect that all that stress and vibrations finally did a number to the EGR pipe.
Should I just order a new pipe, and have it replaced? I mean, I never heard of the exhaust going bad on these babies... but everyone seems to have had the EGR pipe break at least once.
no, it is likely your lower EGR pipe, look in the crinkled part in the bend of the pipe, that is where they crack, and you would definitely smell exhaust fumes, as the fresh air intake is just 18 inches or so above this pipe!
the replacement Toyota part is about $100 if you shop it online, and it is no fun to install!
thanx for replies everyone.
Funny thing is that if I switch to fresh air on the HVAC, I get much less exhaust smell (almost none when its cold), but on recirculate it is actually worse! I thought recirculate would block it all off.
Funny thing is, I only get that exhaust smell on a warmer day, but when it is cold, there is no smell... weird.
you might save $30-$40 after shipping is factored in by going here
probably take 10 days to arrive though
Jeffrimerm
04-24-15 06:33 PM
power54
04-15-14 11:30 PM
