UCF21 ignition coil resitance
Old 03-01-14, 02:21 PM
Greg5OH
Greg5OH's Avatar
indeed. I find it very strange that no code is present. i tried 2 different scanners, nothing. Going to clean the MAF and pull those coils out today, change the plugs. Dont know how old the other ones are, dont care, shes getting new ones.
Thinking out loud here, but a failing crank or cam sensor sounds appropriate as its a violent buck, as in-all coils stop firing momentarily. Ive had plugs foul up to the point the dont fire on my mustang, and its much more gentle than this. strange there is no code , im going to take it to oreileys once my airride manifold it back, maybe they got a better scanner. Nearest toyota or lex dealer is 20 mins away from me and service is usually closed by the time im done work.
Old 03-01-14, 03:32 PM
LScowboyLS
LScowboyLS's Avatar
make sure you only use actual MAF cleaner to clean the MAF - I use CRC brand
and for other folks reading this thread, never use ANY cleaner on a 94 or older MAF (AFM) - you will ruin it! - gentle air and a brand new chamois ONLY.
Old 03-01-14, 03:37 PM
Greg5OH
Greg5OH's Avatar
MAF cleaner specific, or will sensor safe cleaner work?
Old 03-01-14, 05:36 PM
sha4000
sha4000's Avatar
Maybe read a little of this article.
http://www.underhoodservice.com/Arti..._misfires.aspx
Old 03-01-14, 06:01 PM
LScowboyLS
LScowboyLS's Avatar
just be safe and get the stuff pictured below, it's available at most auto parts stores and likely at Wal-Mart even!
Old 03-02-14, 07:44 PM
96blksc300
96blksc300's Avatar
Checking resistance on modern could is rather pointless. They need to be checked on an oscilloscope in order to be read correctly. And even then the results will vary between a cold or hot coil. I would go with the track hour on... The cam/crank sensor. Might check into the ignitor also.
Old 03-02-14, 08:26 PM
LScowboyLS
LScowboyLS's Avatar
this is what Yamae was trying to explain in post #9
about the only time the resistance would tell you anything would be in the case of an open or a dead short in the coil
Old 03-02-14, 10:01 PM
Yamae
Yamae's Avatar
For those who can't use an oscilloscope, there is a simple and easy way to check the ignition coil unit. I have written it at below a few months ago.
http://www.benzworld.org/forums/7495777-post5.html
Old 03-03-14, 08:57 AM
LScowboyLS
LScowboyLS's Avatar
wow! - thanks Yamae! - here is something for you!
Old 03-03-14, 04:44 PM
Gene01
Gene01's Avatar
Utskushi des'.
Jknow82
04-14-18 07:50 PM
Katlexus
03-28-17 06:04 AM
gstreee
12-31-13 03:49 PM
cgreenberg
09-21-12 05:23 AM
dusty80
RX - 1st Gen (1999-2003)
04-02-06 09:33 PM
Quick Reply: UCF21 ignition coil resitance
