Time for New Struts and Springs?
Old 02-11-14, 10:50 PM
lhgdale
lhgdale's Avatar
Default Time for New Struts and Springs?
Hello, I am guessing it is time for new struts and springs on my 92 LS. I am getting a creaking noise when I go over certain bumps and dips in the road from what sounds like the front. I looked these parts up on Sewel's website and they are expensive. Are there any aftermarket brands that will work without ruining the ride quality? Thanks
Old 02-12-14, 12:04 AM
KiNGD206
KiNGD206's Avatar
how much of a budget u got to spend first off?
is it only when its cold or during when the engines warmed up?
Old 02-12-14, 12:59 AM
lhgdale
lhgdale's Avatar
I would like to stay close to 500.00 or less. They do make more noise when it's cold but the noise is still there when warm.
I'm in Alabama and we have had some extremely cold temps recently. I started noticing the noise a few weeks ago.
Thanks
Old 02-12-14, 05:31 AM
billydpowe
billydpowe's Avatar
the OEM were made by KYB, so if you stay with them you will be close.
KYB rebranded the old GR2 line to the Excel-G.
ALSO: this from another posting....
Last weekend I pop the black rubber covering that covers the bolt on the two front suspension when you open the hood and tighten the bolts one on each side, and low and behold the clucking noise was totally gone, I notice my suspension is a little firmer but that annoying noise is gone.
Old 02-12-14, 08:23 AM
Kansas
Kansas's Avatar
Try lubing the front suspension bushings. My 90 LS creaked and groaned when I hit a speed bump and some lube eliminated the noise.
Old 02-13-14, 06:34 AM
OMAHA
OMAHA's Avatar
this is a good thread, i noticed the noise also and thought new struts was in order but i will try these new solutions......freezing in NEBRASKA!
Old 02-17-14, 01:41 AM
lhgdale
lhgdale's Avatar
Thanks for the info. I think rock auto sells the kyb struts. I will ckeck the bolts and lube the bushings in the mean time.
Old 02-17-14, 02:41 AM
LScowboyLS
LScowboyLS's Avatar
also check tirerack.com on the KYB struts, as well as amazon and ebay
Old 02-17-14, 02:59 AM
GH5T
GH5T's Avatar
Got a complete set of KYBs off amazon for a little over $300 plus shipping. The sleves and isolators have to be ordered seperately tirerack sells them.
Old 04-20-14, 06:13 AM
GKLCPA
GKLCPA's Avatar
Bump on this thread. I had the same creaking that began occurring after the cold spell we had back here in PA in Feb/March and my car rides like a wagon, so I figure I'm due for new ones. I put KYB replacements on about 5 years ago and got about 70,000 miles out of them, so I'm a bit disappointed they didn't last longer, but from searching around most aftermarket struts are due for replacement around that mileage anyway. Question---when I replaced these 4.5 years ago, I installed new boots and mounts. I'm thinking that the chances are that those are still good and that I don't need to replace them again at this point. Thoughts?
Old 04-20-14, 08:17 AM
sha4000
sha4000's Avatar
Boots should still be good, either way when you dismantle then you will know real quick. I would think that the shocks would last longer than that though. Are you sure that they are gone?
Old 04-20-14, 08:40 AM
1sWt2GS
1sWt2GS's Avatar
Might as spend an extra couple hundred and get coilovers while your at it.
Old 04-20-14, 10:00 AM
GKLCPA
GKLCPA's Avatar
I'm going to try a bit of tightening and lubing as mentioned up string, but my car rides like a wagon and seems to bottom out on the front end when going over dips and speed bumps. Yeah, I thought they'd last longer than that and the problems only seemed to emerge when the weather got cold.
Old 04-20-14, 10:01 AM
GKLCPA
GKLCPA's Avatar
Yes, I was thinking about that too, but those are for lowering the car as well right?
Old 04-20-14, 12:45 PM
AndyTTT
AndyTTT's Avatar
I have the same creaking noise from the front suspension of my '93 - going over speed bumps when the car is cold. Maybe a stupid question, but which bushes do I lube and with what - silicon spray ok?
Quick Reply: Time for New Struts and Springs?
