LS400 Engine Cover
Old 01-13-14, 11:48 AM
djsurfer
djsurfer's Avatar
Default LS400 Engine Cover
I have a 92 LS400 with no 1uz engine cover and I would like to purchase one but would like to know what modifications will be needed to make fit under the hood if possible to a 1st gen LS. Reason why I'm doing this is because I have everything else custom done in my car, from the interior/paint/wheels/trunk etc, but my engine bay is the only thing almost untouched. Can someone please tell me if they have done it and what had to be done to make fit and clear under the hood. I will be hydro printing woodgrain patterns that match interior trim and VIP tables. Thanks in advance!!!
Old 01-13-14, 02:03 PM
steve2006
steve2006's Avatar
Easy to do,you will need the engine cover and also the mounting bracket which fits on the plenum chamber near the EGR.
Remove the throttle cable cover and relocate the mounting stud to fit the hole in the engine cover,remove the front top wire cover.
To attach the cover use some 10mm dome nuts.
If you pm me your email I can send you detailed pictures of the brackets and mounting.
Old 01-13-14, 07:10 PM
aomdedude1
aomdedude1's Avatar
How about the strut tower covers?
I want them too!! They seem to be hard to find on e-bay.
Old 01-13-14, 07:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
that's because they were only fitted to air suspension cars. Aren't made for normal coil spring cars.
EDIT: the shock tower covers, not the engine cover.
Old 01-13-14, 08:00 PM
aomdedude1
aomdedude1's Avatar
Ohh okay, that clears it up. Did not know that!
Old 01-15-14, 10:12 AM
steve2006
steve2006's Avatar
Mines not on Air Suspension but they were also fitted to the models fitted with TEMS ( Toyota Electronic Modulated Suspension) which has conventional springs and dampers (shock absorbers) but have an ECU controlled motor mounted on top to adjust the amount of damping depending on whether normal or sport is selected.
Old 01-15-14, 01:06 PM
PureDrifter
BahHumBug
TEMS was offered as an option on the LS?
The more you know I guess, was never optioned in north america as far as I know.
Old 01-15-14, 05:49 PM
dc893
dc893's Avatar
I know Celsiors came with TEMS as an option. It helped out a lot in the snow. It had three buttons near the shifter power/normal, TEMS/normal, and high/low.
Old 01-15-14, 06:40 PM
timmy0tool
timmy0tool's Avatar
wait, you want to buy a 1uz engine cover for you UCF10 and wondering if it will clear the hood? it's stock so it should fit with no mods and clear the hood. am i missing something? did UCF10s lack an engine cover?
TCM55
IS F (2008-2014)
06-03-21 12:28 AM
radiokilla
25
06-02-11 04:48 PM
averona
07-29-10 10:34 PM
SC3coupe
07-10-10 02:46 AM
projekt
Performance & Maintenance
07-13-07 09:45 AM
Quick Reply: LS400 Engine Cover
