starting issues
Old 09-16-13, 04:59 PM
jcollis217
jcollis217's Avatar
Default starting issues
at first car starts ok, drive somewhere and stop engine. try to start again no power at all. a little time later it starts. what could my problem be? oh this a 1997 ls 400.
Old 09-16-13, 07:45 PM
Gene01
Gene01's Avatar
When you turn the key to "START" and it does not start, do you get:
1. nothing at all
2. click
3. starter motor turns but not the engine
4. engine turns over, but does not start
5. something else?
Old 09-17-13, 07:03 AM
jcollis217
jcollis217's Avatar
When I turn key everything stops, no lights, no sounds just a dead instrument panel. I wait for a minute with car door open and I get a beep and car door light, lights up I turn the key everything goes dead. About 30 minutes or so the car door lights, lights up, I turn key and it cranks up. It does this intermittently. It may go a day or two before it happens again.
Old 09-17-13, 07:31 AM
Yamae
Yamae's Avatar
Sounds like a poor battery connection to me.
Have you ever checked the battery terminals lately?
Old 09-17-13, 10:14 AM
deanshark
deanshark's Avatar
Mine did pretty much the same thing and it was a bad connection on the alternator due to the leaking power steering fluid. It sure sounds like a bad connection somewhere. I would try the battery terminals first. It could be as easy as just tightening the ground cable on the battery. But....usually with the LS400 nothing is easy.
Old 09-17-13, 11:05 AM
RA40
Super Moderator
RA40's Avatar
+1. Check the battery posts, if these are clean and there are no visible signs of corrosion on the cables, the battery would be the next suspect. The battery's I've had don't tend to go more than 4-5 years before they go south.
Old 09-28-13, 12:03 PM
jcollis217
jcollis217's Avatar
Cleaned positive and negative posts, hadn't had the problem since. Thanks for all the replys
Old 09-28-13, 12:06 PM
LScowboyLS
LScowboyLS's Avatar
if the problem happens again, replace the positive terminal with the one at the Toyota dealership, about $15, and they go out at this age.
Savnout
07-25-16 07:15 PM
Finn
05-07-14 08:54 PM
twadem
03-21-14 05:36 AM
bossladee
SC- 1st Gen (1992-2000)
12
10-30-13 10:31 PM
Willow
03-03-07 11:35 AM
Quick Reply: starting issues
