transmission fluid check, help
Old 07-21-13, 04:13 PM
joelpr1234
10th Gear
joelpr1234's Avatar
Unhappy transmission fluid check, help
I been searching how to correctly check the tranny fluid of a 90 LS400 but i found very different answers, last time the car was warm, about 30 min idling and then about 5 miles run, when i got the stick, tranny was at P (parked) and the stick was marking at top of cold, the hot part was clean, are this correct or i need more fluid?
Thanks
Old 07-21-13, 04:48 PM
Dawa
Dawa's Avatar
sounds like you could use a little more fluid.
Old 07-21-13, 05:15 PM
LScowboyLS
LScowboyLS's Avatar
after a thorough drive, and the transmission good and hot, come to a stop on very level ground and slowly shift though each gear, ending up in park, and then with it still running in park, the level should be at the hot mark (top hole or top of crosshatch area, after wiping down the dipstick and reinserting it
also, a slight bit over is OK, and better than being under filled
Old 07-21-13, 06:18 PM
joelpr1234
10th Gear
joelpr1234's Avatar
Thank you, i need more fluid!!
alcan
18
11-26-23 01:30 PM
manifesto
05-05-18 10:23 AM
priobe
12-18-16 08:51 PM
Miles253
12
12-13-15 09:16 AM
Vegas
02-07-12 02:52 PM
Quick Reply: transmission fluid check, help
