Pinched my coil wire doing tune-up :(
Old 06-09-13, 02:55 PM
Hodson
Hodson's Avatar
Default Pinched my coil wire doing tune-up :(
I was doing all the plugs and wires in my 91 yesterday, and in my frustration I didn't pay attention and routed the left-side coil wire wrong and ruined it when I tightened the timing belt cover back on I put the old one back on to replace it for the time being, but the point of the tune-up was to replace all these old-*** wires, I think they might be original... 210,000 km's old.
The wire set was $130, I won't get warranty because it was 100% my fault that ruined it, and I really don't want to buy a whole new set just for one stupid 6 inch long wire. Does anybody know if the coil wire can be bought separately?
If it makes a difference I got Beck Arnley Blue Thunder plug wires. they were the recommended product at all my local parts stores for my car.
Old 06-09-13, 03:14 PM
RA40
Super Moderator
RA40's Avatar
I'd call the wire company and tell them what happened. Some of the CS reps are compassionate and you may get them to send you a wire. At worst they my charge a reduced fee for a new replacement single wire.
Find a specialty speed/ignition shop that custom makes wires. They can do one for about $20-$40 depending what characteristics you want. Might be less too.
Old 06-09-13, 03:51 PM
LScowboyLS
LScowboyLS's Avatar
not sure why you are spending $130 in the first place - Lexus OEM's Nippon Denso and NGK sell the OEM wires for around $75 if you are a good online shopper
personally, if I was in your shoes, I would just buy the real OEM No 1 coil wire from the dealership at a 20%-25% discount which most any of them will give ya or else order it online from Sewell Lexus or other online Lexus dealership - the original coil wire is Nippon Denso and about as fine as money can buy!
either way, you are only talking like $14
the part number is 90919-13333
Old 06-09-13, 04:00 PM
johnnyg66
johnnyg66's Avatar
Been there done that. I went to autozone even tho i didn't buy my set from them. And the manager gave me just a coil wire for nothing. Sure is easy to pinch them if your not watching close enough.
Old 06-10-13, 08:15 AM
Hodson
Hodson's Avatar
Awesome! Exactly the response I was looking for, thanks guys!
Old 06-10-13, 10:29 AM
timmy0tool
timmy0tool's Avatar
so it pinched enough to actually break the wire or harm the insulation enough to warrant a replacement? i would think the wire is strong enough to withstand a pinch from a plastic timing belt cover.
regardless i agree with LScowboy, OEM plug wires are the way to go!
Old 06-10-13, 10:56 AM
johnnyg66
johnnyg66's Avatar
It adds resistance to the path.
Old 06-10-13, 02:54 PM
Hodson
Hodson's Avatar
It got caught under the cover and also in the path of the lower bolt for the timing belt cover, I routed it wrong. The bolt shredded through the rubber insulation and did a number on the wiring inside
LexBrett
05-19-15 12:02 PM
miles56
03-02-11 08:34 PM
V8drummer
Performance & Maintenance
08-25-10 05:18 PM
EastWind
04-03-07 08:21 PM
Taka
SC- 1st Gen (1992-2000)
05-17-02 07:01 AM
Quick Reply: Pinched my coil wire doing tune-up :(
