Speedometer gauge stuck..on 98 ls 400
Old 05-20-13, 05:04 PM
TONY1022
TONY1022's Avatar
Angry Speedometer gauge stuck..on 98 ls 400
Hey Guys...
My speedometer gauge sometimes stucks , doesn't move at all. Other times it could be fine.
Meaning I could be on a highway and not knowing what speed I'm at .That has been going on for a while and I'm not sure what's wrong and how to solve the problem.
Ur input will be appreciated.
Old 05-20-13, 05:13 PM
Lavrishevo
Lavrishevo's Avatar
There is a thread on here about the sticky needle. I also have this. Both the tach and speedometer are prone to have these problems. I think the 98 - 2000 models suffer from this mostly. Especially, when the weather warms up and the car has been exposed to a hot climate.
The problem has to do with some kind of substance that gets on the needle stop. It sticks the needle in place. One of the solutions is to pull the cluster out and disassemble it / clean the problem areas. Not an easy procedure but $250.00 less then paying someone else to do it. Long q tip with rubbing alcohol.
Just make sure it is this by hitting the top of the dash when it is stuck. This will usually release it. Just give it a good thunk on top.
Old 05-20-13, 05:37 PM
bdan
bdan's Avatar
Originally Posted by Lavrishevo
There is a thread on here about the sticky needle. I also have this. Both the tach and speedometer are prone to have these problems. I think the 98 - 2000 models suffer from this mostly. Especially, when the weather warms up and the car has been expose to hot climate.
THANK YOU SIR. I have this problem too but never really decided to fix it. Doesn't really matter cause I cruise super slow with my LS anyways.
Old 05-20-13, 08:46 PM
LScowboyLS
LScowboyLS's Avatar
Not always the root of the problem, my '96 had sticking speedometer that you had to whack the dash, once I fixed my leaking ECU capacitors, the problem has been gone for a year now!!
PS - if you are on the highway traveling and worrying that you might get a ticket because you are not sure how fast you are going, there is a great and very accurate free speedometer app for Android called SpeedView - it saved my butt many times from the cops until this problem was fixed!
Old 05-20-13, 08:56 PM
dengman
dengman's Avatar
i wack my dash.
Old 05-21-13, 10:30 AM
billydpowe
billydpowe's Avatar
Originally Posted by dengman
i wack my dash.
me too, on both 99's
Old 05-21-13, 01:22 PM
Legender
Legender's Avatar
I wack the dash on the 95, but have not seen the problem on the 99 or the 2000... guess I have something to look forward to...
Old 05-22-13, 12:10 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
Forum Vendor TaninAuto can fix this, i've been meaning to send them my cluster for a while now.
Benen
02-10-17 06:49 PM
BLK98GS3
SC400 / 300 Classifieds
01-22-12 10:37 PM
LexLS
49
01-12-11 10:41 AM
qewani1
12-14-08 10:04 PM
GRAND_LS 4
03-07-05 11:45 AM
Quick Reply: Speedometer gauge stuck..on 98 ls 400
