Help! LS Navi screen white
Old 01-31-13, 08:03 PM
LMoney4o8
LMoney4o8's Avatar
Default Help! LS Navi screen white
The screen works when you touch it but the screen is white. Does anyone have a solution to this? 99 LS, thanks
Old 01-31-13, 11:24 PM
Yamae
Yamae's Avatar
The white screen means that there is no drive signal to LCD cells. It may be caused by the failed driver or the failed DC supply circuit which supply the DC to the driver.
I don't remember the detail of those circuits but what I would try is to check the SMD fuse on the board.
BNastee (11-03-23)
Old 02-06-13, 10:53 AM
LMoney4o8
LMoney4o8's Avatar
Is it fixable?
Old 02-06-13, 04:10 PM
Yamae
Yamae's Avatar
It is up to your skill and the availability of the failed part.
Old 06-16-20, 12:01 AM
SHOtyme
SHOtyme's Avatar
any solution to this???
Old 06-16-20, 06:06 AM
saleenssc
saleenssc's Avatar
ive had the same issue in my 98 for about a year now. screen is white 100% of the time but it still responds to touch. I think im just going to purchase a non-nav hvac panel. I dont really listen to the radio or cds in the car anyways.
Old 07-29-20, 07:49 PM
chuck58
chuck58's Avatar
My 2000 LS-400 displays this behavior, during the colder months of the year. We live in the deep south, so it's not that often. After the car warms up to operating temperature (about the time the heater comes on), I find that I can shut the car off in the normal manner, take the key out, wait 5 or so seconds, re-start the car, and the screen behaves normally. Any idea what may be causing this? Remedy(s)?
Thanks
Old 07-29-20, 08:20 PM
JohnAndic
JohnAndic's Avatar
Probably just old display tech aging
Old 07-29-20, 08:30 PM
Yamae
Yamae's Avatar
That's a typical symptom of a failing DC-DC converter circuit in the navigation unit. It is mostly caused by failing electrolytic capacitors used there.
Electrolytic capacitors decrease the capacitance when cold. As those capacitors age, the capacitance decreases in accordance with the Arrhenius equation and your type of problem tends to be caused because the capacitance becomes already low enough to have a problem. A skilled guy would be able to fix it simply finding failed capacitors and replacing them. A
ESR meter ESR meter
would be useful to find failing capacitors, I must add.
BNastee (11-03-23)
Old 09-20-20, 02:15 AM
emaster
emaster's Avatar
it is most popular trouble of this multivision
a reason in graphic pcb fault
a picture is missing but backlight is present (white screen)
i do repair this trouble about 4 years (wright post on russian forum)
https://club-lexus.ru/forum/viewtopi...398717#4398717
now i do repair by full change a internal parts (graphic controller and lcd) on new version (led lcd and new pcb with 2av and rgbs inputs)
in this case white screen trouble is missing forever and add more functions (rearview camera and video input for multimedia player) as upgrade after repair
for example
Old 06-02-21, 11:31 AM
emaster
emaster's Avatar
it can be repaired
Old 05-15-23, 07:32 AM
Yamae
Yamae's Avatar
I know this is an old thread but I now have some additional information here.
BNastee (11-20-23)
Ganakaray
05-31-19 12:29 PM
PAVGR
02-28-17 03:13 PM
Lowkey6974
07-01-14 07:14 AM
Quick Reply: Help! LS Navi screen white
