california car
Old 10-02-12, 04:30 PM
bstains
bstains's Avatar
Default california car
Wondering if I could get some help, Iam having a bank 1 catalytic code pop up on my 2000 ls400. I replaced the converter and still having a problem. Was wondering if i have a California emission car and how to tell.
thanks
Old 10-02-12, 04:37 PM
Lavrishevo
Lavrishevo's Avatar
thanks
It will tell you on the sticker under the hood. It says CA on there somewhere I believe. I had the same problem.
https://www.clublexus.com/forums/ls4...r-lessons.html
Old 10-02-12, 05:43 PM
Kansas
Kansas's Avatar
The 2000 LS400 sold in the 48 contiguous U.S. states had the ULEV certification (Ultra Low Emmisions Vehicle). There was no separate version for California.
Old 10-02-12, 08:09 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
give us the code...
if it was p0430/p0420 then you probably should have looked for exhaust leaks before replacing the cats....
Old 11-15-12, 02:03 PM
snoop562
snoop562's Avatar
sorry o revive this thread but does anyone know if th 99 ls400 is a ULEV certification (Ultra Low Emmisions Vehicle)? thanks!
Old 11-15-12, 03:37 PM
PureDrifter
BahHumBug
negative, the LS430 was one of the first gas v8s to get that cert.
Old 11-15-12, 05:14 PM
Kansas
Kansas's Avatar
I stand corrected. The 1999-2000 LS400 was T-LEV ... Transitional Low Emission Vehicle
Old 11-16-12, 10:51 AM
snoop562
snoop562's Avatar
thanks guys!
the reason im asking is cause im picking one up this weekend, the owner said he cracked a cat from driving low. i was wondering which would be the correct aftermarket cat to replace it with? thyanks.
Old 11-16-12, 02:04 PM
PureDrifter
BahHumBug
thanks guys!
magnaflow makes one that's bolt-in. don't worry about the california-only one as that's just for CARB smog purposes.
Old 11-16-12, 04:32 PM
snoop562
snoop562's Avatar
I live in las Vegas we get smog checks here, can I still get the one thats not for California?
Old 11-16-12, 05:19 PM
PureDrifter
BahHumBug
yeah, the cali cats cost more because california now requires all OBDII+ cars to use "registered" cats, which usually cost a fair bit more.
A cat made for CARB spec but not necessarily "california approved" should work fine.
Call magnaflow, i'm sure they'd be able to clarify further.
Old 11-16-12, 07:50 PM
snoop562
snoop562's Avatar
Smile
Thanks, that's very helpful!
mar1
46
10-15-15 09:51 PM
Urnot99999
06-03-14 09:05 PM
Abdiel
06-10-11 10:09 AM
91LS400LEX
01-08-10 05:45 PM
91ls400own
04-28-09 09:11 PM
Quick Reply: california car
