What could cause this? (Steering wheel tilt working & not)
My tilt function has never worked since the car was aquired, its a 1991 LS400. The other day when my battery cable came loose, and I twisted it back on, all of a sudden the wheel tilt function was working. It worked for about 30 mins, I kept testing it while i was driving, then it stopped again. Could it be a weak relay, that got jolted when I was reattaching the battery, are there any relays for the tilt, if so where r they located?
Thanks
Thanks
i ran into the same issue, mine worked since i purchased the car (93 ls400). then all of a sudden when i started having mechanical issues, suddenly the steering wheel wont drop. it telescopes, but wont drop. i can hear the motor, no grinding, or no issues, just acts like its hit a limit switch.
There is a known issue and documented fix for the steering wheel. It's an easy job where you basically shim the little gear with a piece of plastic. It's probably linked on these forums.
Mine did same thing shimed it with zip tie gears were fine in mine to just not catching
Mine was just the opposite. After no power (once changing battery, once changing alternator) my tilt stopped working for a short time and both times came back. Telescope, seats, and mirrors were not effected.
JacketJet
08-31-17 06:04 AM
Gs L-tune
10-17-05 09:05 AM
