Rrear Rotor Retaining Screws help
Old 07-29-12, 06:00 PM
LS400BOY
LS400BOY's Avatar
Default Rrear Rotor Retaining Screws help
need help on the best way to remove the 2 screws thats on the rotor so i can remove the rotor? i used my screwdriver but im striping them so its getting real hard to screw them out
Old 07-29-12, 06:15 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
impact driver. google it.
Old 07-29-12, 06:46 PM
LS400BOY
LS400BOY's Avatar
you hell puredrifter lol i was looking at a diy page and wished the mentioned that lol
Old 07-29-12, 08:14 PM
LS400BOY
LS400BOY's Avatar
sucks because i aint got no air compressor
Old 07-30-12, 08:24 AM
DonCorleone
DonCorleone's Avatar
drill out the head.
Old 07-30-12, 10:03 AM
LS400BOY
LS400BOY's Avatar
if i do that do they sell these screws at a parts store like autozone or something??
Old 07-30-12, 11:35 AM
PureDrifter
BahHumBug
Forum Moderator
Impact Drivers aren't air tools! pneumatic impact drivers are.
http://en.wikipedia.org/wiki/Impact_driver
all you need is an impact driver, a bit, and a hammer.
Old 07-30-12, 03:39 PM
LS400BOY
LS400BOY's Avatar
damn u just made me feel retarded lol ill give that a try,i dont know what i was thinking
Old 07-31-12, 10:55 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
taken from this thread:
https://www.clublexus.com/forums/ls4...0-ls400-2.html
i use an impact driver to remove those bolts that hold the rotor to the hub. it prevents stripping as you pound it out using a hammer (in my case, mini sledge). i never use a regular screwdriver. spray some PB Blaster or WD40 to loosen the threads.
NOTE: this was on my honda but the principle remains. you can see the sledge in the background.
if you stripped the heads, you can make a slot into them using a dremel, then use a flat head bit on the impact driver to get it out.
Old 07-31-12, 03:48 PM
PureDrifter
BahHumBug
Forum Moderator
just wanted to add, the reason this works is because phillips head screws are designed to Cam-out when reaching breaking torque, flat heads aren't. So if the screw's well and truly seized you can break the flat head bit before getting it loose.
TL;DR: Wear eye protection.
Old 08-01-12, 10:06 AM
LS400BOY
LS400BOY's Avatar
i just got a big flat tip screw driver and hammered it out,now having the hardest time getting the bolts from the back side of the brake caliper bolts so i can take it off to remove the rotor
Old 08-01-12, 11:33 AM
DonCorleone
If you drill out the head, you can replace the screws with stainless ones from the hardware store or run without them. Their main function is to locate the rotor while you put everything back together, debatable if you absolutely need them.
For the Caliper bracket bolts, 6pt socket, some pb blaster or liquid wrench and a breaker bar. A couple of whacks with a rubber mallet if it's on there good. Remember, lefty loosie, righty tighty.
Old 08-01-12, 01:25 PM
LS400BOY
LS400BOY's Avatar
thats good to know about the screws, so turning the bolt left will undo them? i thought to your right clock wise will loosing the up since its on the oppisite side of the rotor turned the other way????
Old 08-01-12, 02:14 PM
acidfire52
acidfire52's Avatar
i had to extract all of mine here recently. Am going to run with out them.
Old 08-01-12, 02:35 PM
LS400BOY
LS400BOY's Avatar
good because i didnt know where to get the screws if i had to use them but so whats the rubber part for then?
Quick Reply: Rrear Rotor Retaining Screws help
