Low coolant temp, stalls
Hi, trying to troubleshoot my dads '98 LS400.
It's only started recently where once the car has warmed up, his coolant temp gauge will drop intermittently. Then when the car comes to a stop at a light, the car will sometimes (not always) stall and won't start until 10 or 15 minutes later. If the coolant temp gauge stays normal, the car won't stall.
I've tried changing the thermostat, but the first time I took it for a drive afterward, the coolant gauge was pinned at C, even after 10 minutes of idling and a 5 minute drive. When I slowed down and nearly came to a stop, the car stalled. Had to wait 5 minutes before the car would start again. Any ideas as to what the issue could be?
Sounds like a coolant temp sensor or ECU related issue. I would check the voltage at the coolant temp gauge first.
https://www.clublexus.com/forums/ls4...ange-pics.html
Do I have to take the cluster apart to check the voltage at the coolant temp gauge? I'm not too familiar with Lexus.
What's an ECT? Is that the same as the ECU?
Is there a separate writeup for the '98 somewhere, or are they similar enough that I could go off the one for the '95? I know the engine bay does look slightly different.
LoveSCs
Performance & Maintenance
07-11-16 03:50 PM
