Tire noise & cupping
Old 11-13-02, 08:53 AM
dealerflorida
dealerflorida's Avatar
Unhappy Tire noise & cupping
Hello I am new to this forum. I own a 1997 LS 400, Diamond white pearl, has Nakamichi & I am at 82,000 miles.
At 71,000 miles I replaced the 2 front tires with Michelin MXV 4plus to match 2 good tires.
I noticed a whirring sound recently, almost like a bad bearing sound (For example). I also noticed in certain light and at certain angles the tire is wearing down unevenly. In certain areas of tire rubber is lower, or worn deeper than others.
What is causing this?
What fix, or parts change is needed?
Are the tires ruined?
Appreciate what ever advise I can receive.
Sheldon
Old 11-13-02, 11:28 AM
tn52
tn52's Avatar
Default tire cupping
Check your car 4 wheels alignment for toe settings. It's very likely your problem. Also check for your front struts. They're getting old but should have a lot of life left. Depend on the damages, yes your tires are ruined. You can either live with the noise or buy another set of tires.
Old 11-13-02, 03:04 PM
hyperopt
hyperopt's Avatar
Balance, alignment, and/or suspension worn. Most likely worn suspension parts (eg. shocks) but out-of-alignment can send your tires south. Depending on the severity of uneven wear, the tires may never return to acceptable roundness after fixing the culprit(s). In the meantime, you'll either have to put up with the noise or toss them.
Welcome to ClubLexus Edmund man!
Old 11-13-02, 03:34 PM
chliansh
chliansh's Avatar
Default FWIW
You might to search the site, if I remeber right there is a bushing prone to wear out on the upper control arm.
kayjon
06-24-18 04:38 PM
maximakid
03-26-13 02:51 PM
NedaK
11-03-10 09:57 PM
oldcajun
Hybrid Technology
10-01-06 08:10 PM
Timestwo
08-15-06 09:35 PM
Quick Reply: Tire noise & cupping
