Replacing struts, KYB or Strutmasters or?
Old 11-30-11, 11:56 PM
ck90211
ck90211's Avatar
Default Replacing struts, KYB or Strutmasters or?
Had enough miles on old struts ('95 with 160K miles) so looking to replace struts (all 4), mounts and maybe the bellow/stops.
4 sets of KYB's with mount/bellow came out to be $620, which is more expensive the 4 strut assemblies (with new springs) from Strutmasters ($ 609). And since I am doing it myself I would prefer not having to compress the springs (thus I prefer pre-assembled Strutmasters).
I plan to call Strutmasters but like to get some unbiased/2nd opinions.
Question 1: Can I just swap the old strut assemblies (no air suspension) with new Strutmasters without any mods?
Question 2: Any experience or comments on ride or reliability of KYB vs. Strutmasters? I need good damping over rough roads (more than plush/soft ride) because the roads are bad where I drive.
Question 3: Any other suggestions on cheaper or better alternatives for about the same money?
Just bought tires and over $1000 of rubber parts (mounts, flexible couplings, ball joints, etc.) so just don't have the will to go OEM on struts. Thanks for any comments/help.
Old 12-01-11, 07:54 AM
RA40
Super Moderator
RA40's Avatar
The task isn't that difficult swapping springs and mounts. Rent a spring compressor, this will save you some $ over replacing the springs and mounts which are probably fine in the first place. That has you in the $350 for the struts.
The instances I see for replacing the mounts and springs is if your car has seen the harsh winters where roads are salted or in other seaside type environments where corrosion is a factor.
Old 12-01-11, 08:33 AM
oldskewel
oldskewel's Avatar
I agree completely. I replaced all 4 on my '91 with KYB's recently.
You can "rent" the spring compressor for free at Pep Boys or O'Reilly's (Kragen's). You buy it and then return it for a full refund within 2 (O'Reilly's) or 5 days (pep boys). It helped me when I did mine to have an air gun to drive the spring compressor, otherwise it would have been a little tedious.
I bought KYB mounts before taking things apart and then found the original ones (170k miles) to look just fine. I installed the new ones anyway since I did not want to deal with return hassle. I saved the old ones, along with some other stuff (boots, etc.) that were in fine shape. But I agree, chances are you will not need them unless you have some specific reason to think otherwise.
Regarding "Just bought tires and over $1000 of rubber parts (mounts, flexible couplings, ball joints, etc.) so just don't have the will to go OEM on struts.", are you sure you need struts? I replaced all 4 at ~170k miles on my '91, and sure it tightened it up a little, but if I were wavering on "the will", it could have easily been something to not do at all. Those OEM struts are pretty good. I'd say maybe one of the 4 I threw out was really finished.
Old 12-01-11, 10:56 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
if you're REALLY scared of compressing the springs yourself, most local shops will do that with their wall-mounted tools for relatively little money if you ask and take them the spring/shock assy. off the car.
Old 12-01-11, 11:50 AM
RA40
Super Moderator
RA40's Avatar
If you don't want to do the job yourself the average rate is $50 a corner. These guys can be pretty fast so consider how much time it may take you do do the install yourself. A good shop can have you in-out in about an hour some odd.
Old 12-01-11, 02:15 PM
LiCelsior
Retired
LiCelsior's Avatar
i think my coilovers for sale might be less expensive than that total after labor.
Old 12-01-11, 04:34 PM
ck90211
ck90211's Avatar
Thanks guys. I am doing all these at once because the car is going to Cambodia soon (for 2 year job assignment), and any parts (OEM or aftermarket) will be pricey, and roads much harsher than SoCal's.
Old 12-01-11, 05:58 PM
PureDrifter
BahHumBug
lol no, plus they wouldn't ride close to stock.
do they even go up to stock height? i know my megans won't lol.
Old 12-05-11, 07:25 AM
ck90211
ck90211's Avatar
Ended up buying KYB struts from Amazon, with prime it was $361 for 4 with 2 day shipping.
ES300TX
05-21-18 02:47 PM
BlckGhst
Suspension and Brakes
11-24-16 07:29 PM
850Lexus
01-17-12 10:38 AM
km02LS430
10-06-11 04:01 PM
Bud
RX - 1st Gen (1999-2003)
10-04-07 07:30 AM
Quick Reply: Replacing struts, KYB or Strutmasters or?
