cleaning the ecu
Old 09-21-11, 10:10 AM
Dtwillis5
Dtwillis5's Avatar
Default cleaning the ecu
I about to change the capacitors but before I change them I want to clean the ecu. I use alcohol but it only took off the clear stuff, I try to find something else u can use to get up the brown stuff.
Old 09-21-11, 05:48 PM
LEXTEK1
LEXTEK1's Avatar
Alcohol and a Q-Tip will work just fine. Rubbing alcohol that is, not the stuff you drink!
Old 09-22-11, 09:56 AM
Dtwillis5
Dtwillis5's Avatar
That what I used it don't clean it all the way it leave a brown looking look to it, like it dry it up or something
Old 09-22-11, 11:04 AM
LEXTEK1
LEXTEK1's Avatar
Dont worry about it being discolored. Just neutralize the leaked electrolytic's and it will be fine.
Old 11-10-11, 11:18 AM
Dtwillis5
Dtwillis5's Avatar
Ok I cleaned the ecu and replaced the capacitors and it run the same I didn't get a chance to see if it pull codes cause it got dark with that daylight savings time. I have a 94 w/trac and the ecu i test is a 93 w/o trac ( didn't want to mess up the 94 ecu) will that make a difference or the 93 w/o trac ecu bad to where it can't get fix?
Old 11-10-11, 12:10 PM
Raddison
Raddison's Avatar
https://www.clublexus.com/forums/ls4...-94-ucf11.html
Problem solved
Old 11-10-11, 01:44 PM
Dtwillis5
Dtwillis5's Avatar
Default .
Originally Posted by Raddison
Ill wait till I find one at a junk yard or pay to get mine repaired much cheaper
Old 11-10-11, 02:10 PM
Hilux22RE
Hilux22RE's Avatar
Is one of these Worth it?? You have Caught my attention. What is the Difference Between This and a Regular ECU??:uh
Old 11-10-11, 03:12 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
search for "mine's" in this forum (use the top bar, google is better for punctuation) and you'll find a few posts on members who'd picked them up cheap. consensus is generally they're a solid performance boost of a few HP.
Old 11-10-11, 09:27 PM
Dtwillis5
Dtwillis5's Avatar
I'm going to search , I'm not gon just buy that and it be broke too!
lexdud
Performance & Maintenance
18
08-20-23 10:15 PM
R3Y
SC- 1st Gen (1992-2000)
02-23-12 08:06 AM
Klaus
05-17-10 05:59 AM
al-ex-us
Performance
08-25-09 10:37 PM
jayzsun
01-17-06 11:34 PM
Quick Reply: cleaning the ecu
