my1993ls400 wont start
Old 07-22-11, 09:34 AM
KINGB
KINGB's Avatar
Default my1993ls400 wont start
went to get in it today and it just turns over , kinda fast?!?!? anybody else had this problem?? I havent had any issues before this.
Old 07-22-11, 09:42 AM
deanshark
deanshark's Avatar
Kinda fast points toward low, or no, compression. Did the timing belt snap? How was it running before, and is there any engine codes? Try pulling the codes and post them. http://www.lexls.com/tutorials/intro/codereading.html
Old 07-24-11, 10:41 AM
KINGB
KINGB's Avatar
No codes ,timing belt was replaced last year, and its been running great
Old 07-24-11, 10:43 AM
trukn1
NELOC Mod
trukn1's Avatar
Agreed,, fast turn over normally points to a snapped timing belt. Gonna have to pop the cover off to check.
Old 07-24-11, 10:57 AM
deanshark
deanshark's Avatar
If the T-belt did snap you would probably have a code. (multiple) But to check you will have to remove one of the upper timing covers. The drivers side is easiest. Use steps 11, 14, 15, in this tutorial; http://www.lexls.com/tutorials/ignition/sparkplugs.html
Old 07-24-11, 01:36 PM
willhickey
willhickey's Avatar
what about if the starter wasnt shooting out?
Old 07-24-11, 01:44 PM
deanshark
deanshark's Avatar
Then the motor wouldn't be turning, just a loud whine from the starter motor.
Old 07-24-11, 01:49 PM
python
python's Avatar
look at one of the distrubtor rotors and see if it is turning during cranking
Old 07-24-11, 08:44 PM
willhickey
willhickey's Avatar
haha im an idiot, haha
Old 07-30-11, 10:03 AM
KINGB
KINGB's Avatar
Im going to try the ignition coil , then go from there
Old 07-30-11, 11:26 AM
emarknot
emarknot's Avatar
nope....Captian Obvious just decided to walk past your door.
he has missed my house from time to time....sometimes when I drive away, I see him in the rearview going with a sigh that says....sorry I missed you
I agree though...sounds like the timing belt..........or more so the tensioner if it didnt get replaced when the belt was done a year ago.
Old 07-30-11, 12:56 PM
KINGB
KINGB's Avatar
i dont think the tensioner was replaced, will check that
Old 07-31-11, 05:59 AM
deanshark
deanshark's Avatar
Even if it was changed it could still be bad. I had one that only lasted 14K miles. When I took it off it wasn't out far enough and I couldn't even push the rod back in with a vice. It's easy enough to see if ya have a problem with the belt, just pull off a timing cover and see if the belt is still there. If it's in one piece, take the other cover off and see if all the timing marks line up.
Old 08-06-11, 05:13 PM
KINGB
KINGB's Avatar
It was a bad ignition coil. thanks guys
fastegg
16
08-25-16 09:12 AM
sancarlos1
03-26-15 01:48 PM
Neil4Speed
Performance & Maintenance
11-03-11 01:37 PM
Scott1258
05-15-11 02:41 PM
MuGGzyx
05-20-10 08:45 PM
Quick Reply: my1993ls400 wont start
