will removing the rear mufflers increase performance?
Old 05-12-11, 03:37 PM
GX470GT
GX470GT's Avatar
Default will removing the rear mufflers increase performance?
I mean the ones at the very rear. Also, Is the exhaust on the gs400 similar to ls400?
Old 05-12-11, 03:52 PM
Hilux22RE
Hilux22RE's Avatar
Removing the rear mufflers will not increase performance from what i know of..
I Did remove the two rear Resonators on my 1991 LS400.
But what years are you talking about in the GS to LS Comparison??
Old 05-12-11, 04:03 PM
3UZFTE
3UZFTE's Avatar
No, only noise. There 2 resonators, not to be confused with cats, and 3 mufflers. Try unbolting the mufflers at the rear axle and tie them up out of the way of the exhaust, rev the engine a few times and see if it's for you.
What's your definition of similar? Yes, their both V8s, yes they both have y-pipes with dual exhaust. The GS400 and later model LSs got a higher, I believe 10.4:1, which increased the power, as well as the introduction of VVT-i.
Old 05-12-11, 04:06 PM
Hilux22RE
Hilux22RE's Avatar
Originally Posted by 3UZFTE
No, only noise. There 2 resonators, not to be confused with cats, and 3 mufflers. Try unbolting the mufflers at the rear axle and tie them up out of the way of the exhaust, rev the engine a few times and see if it's for you. Good luck.
Are there not 3 Cats, 2 Resonators, and 2 Mufflers..?
At least that is how mine was.
Old 05-12-11, 04:39 PM
radiokilla
radiokilla's Avatar
Yeah same with my car. California cars have a 3rd catalytic converter in place of the 3rd resonator found on non-CA cars.
Old 05-12-11, 05:04 PM
Hilux22RE
Hilux22RE's Avatar
Now is the 3rd Cat needed?? Or can i get that S*** Cut off?? i was thinking about it but i was thinking it might affect the Smog status...
Old 05-12-11, 08:32 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
some UCF10s had a 3rd cat, but not all. you could probably ditch it without adverse effects but for smog....who knws.
Old 05-13-11, 01:05 AM
Justinkm
Justinkm's Avatar
removing the 2 resonators and that 3rd cat is Ok Passed smog easily
Old 05-13-11, 04:30 AM
maxx999
maxx999's Avatar
Just run open headers, you will probably lose power down low but gain it uptop and it will sound great!
Old 05-13-11, 06:00 AM
3UZFTE
3UZFTE's Avatar
Sorry, I didn't know Cali cars had a 3rd cat, now I do.
Old 05-13-11, 06:11 AM
acidfire52
acidfire52's Avatar
Now that would be loud.
Old 05-19-11, 10:19 PM
KoukiMonst
KoukiMonst's Avatar
just run a cutout
Old 05-20-11, 01:14 AM
PureDrifter
BahHumBug
Forum Moderator
Originally Posted by KoukiMonst
just run a cutout
this would help how exactly....?
Old 05-20-11, 07:40 PM
fatcat2
fatcat2's Avatar
dont do any of the mentioned above. messing with the back pressure of the exhaust will eventually(it will take a while but it will happen) start bending your valves. just get a custom exhaust from a muffler shop. they can tuck it up for you so it can be hidden if you would like.
Old 05-20-11, 07:49 PM
Hilux22RE
Hilux22RE's Avatar
How would reduced back pressure bend valves Exactly...? I Have never heard of this happening. any links to articles or info on this??
Quick Reply: will removing the rear mufflers increase performance?
