'98 Nakamichi headunit replacement
Old 03-03-11, 07:18 AM
NisMax
NisMax's Avatar
Default '98 Nakamichi headunit replacement
I currently have a Nakamichi and I was wondering if it fails, can I swap in a non-Nakamichi headunit from a '98-00 with no problem? Will the sound quality remain the same?
Old 03-03-11, 07:20 AM
NisMax
NisMax's Avatar
Also, I have the factory CD changer.
Old 03-03-11, 12:51 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
non-nak wont plug into the harness, the system is set up completely differently so you'd have to ****** the amp and wiring harnesses from the amp, headunit, and possibly cd changer.
Old 01-24-12, 05:51 PM
reginald91
reginald91's Avatar
NisMax did you have any luck? I am looking to replace my Nakimichi HU also. I will go either original or aftermarket, whatever works and can sustain the sound quality I have enjoyed for the last 10 years. Check out this post I posted today. Sounds like I have the same original set-up as you. Thanks.
Old 01-24-12, 05:57 PM
reginald91
reginald91's Avatar
NisMax,
Check my post.
https://www.clublexus.com/forums/gs-...ml#post6968641
Old 02-03-12, 07:26 PM
Glove81
Glove81's Avatar
I drive a 99 that had a Nakamichi 6 disc system in it and just replace it with a double Din touchscreen. I had a shop do it and they had to wire it themselves since there is no wire harness made and they also had to do an amp bypss. I got them to do it all for 500$ including the unit i got from them. The sound is better with the new head unit but they werent able to bypass the sub so its not hooked up. Im getting new speakers and and amp installed tomorrow so im completing redoing the system but it works just fine adding a new headunit if you get someone that knows how to do the amp bypass.
http://www.onlinecarstereo.com/CarAu...-P2300DVD.aspx
Old 03-04-12, 06:16 AM
VanCityLS4
VanCityLS4's Avatar
No need for a new thread. My question is the same...
I have the Nakamichi in my 99'. Im sic of the Ipod tape adapter. After learning that the Beatsonic does not apply. I searched for hours... Is there not a kit on the market where I can retain my NAK speakers/amp/sub with an aftermarket double din ?? Has anyone sucessfully done this ?
I know I want the Beatsonic woodgrain kit, probably a decent Pioneer or Alpine but can I easily use my above mentioned components without paying someone hours to figure it out ?
Thx
Old 03-04-12, 07:30 AM
PureDrifter
BahHumBug
Forum Moderator
if all you want is an auxiliary input why don't you just do this?
https://www.clublexus.com/forums/lex...em-stereo.html
Old 03-04-12, 01:44 PM
Glove81
Glove81's Avatar
This looks like the best solution unless you want to go ahead and replace the whole system. I just replaced my whole Nak system in my 99 LS and it took me about 14 hours and was some what of a pain to do. I had 6 local shops quote me on prices and they were all between 550$-800$ in labor alone to do it. but after puting in the aftermarket system the sound difference is night and day.
Old 03-04-12, 02:14 PM
VanCityLS4
VanCityLS4's Avatar
PD - I've read your thread like 5 times. It's a great concept but I was trying to avoid any hacking if there was a plug & play option. I understand about 75% of it, but know for sure I've retired from wiring anything after my last car. I know of a IPod kit that directly hacks into the FM radio but first I must track it down & see if it works on the Nak.
Glove81 - I kind of figured the above option would be the affordable solution. I've thought of ripping out everything & starting fresh you did. Those labour rates are reality check if you want someone else to do it...
stopdrpnro
11-18-14 12:04 PM
Vitamin-SC
SC400 / 300 Classifieds
06-30-05 07:36 AM
mailrail
RX - 1st Gen (1999-2003)
07-17-04 10:29 PM
92 sc three
02-02-04 10:05 PM
iampraneel
05-12-03 05:27 PM
Quick Reply: '98 Nakamichi headunit replacement
