Cruise Control Problems
Old 01-31-11, 11:16 AM
penoffdr
penoffdr's Avatar
Default Cruise Control Problems
93 LS400 Cruise Control will not engage, no dash light comes on. Is this likely to be an ECU issue?
Old 01-31-11, 11:35 AM
JimsGX
JimsGX's Avatar
Does the horn work okay?
Old 02-02-11, 01:29 PM
penoffdr
penoffdr's Avatar
Default Cruise Control Follow Up
Horn works fine.
Sorry for the delay, I am in Indiana and I had to get through 1/2" of ice on the car to get in.
Thanks for your help.
Old 02-19-11, 06:33 PM
Y0UNGLEXUS
Y0UNGLEXUS's Avatar
So how did you fix the problem? Because my cruise control just stopped working out of know where. So i want to know what you did.
Old 02-25-11, 04:39 PM
penoffdr
penoffdr's Avatar
I have not found the solution yet. A recent post talked about diagnostics but I don't even get the light on in the dash display when I try to engage.
If I don't hear from anybody that can help I may try to replace the ECU as that is relatively easy and inexpensive.
Old 02-25-11, 05:48 PM
AzHotLS
AzHotLS's Avatar
It could be the clockspring (spiral cable assembly). My horn wasn't working and replacing the clockspring fixed it. If your dash light isn't coming on, it's a good indicator a pin or two on the clockspring are bad.
it's easy to test without removing it.... disco negative battery lead, remove the column cover and air bag. Disconnect the cable connectors from the front and back of the clock spring and check for continuity. If buying a replacement on eBay, have them validate continuity on it before buying.
Woozy
22
10-08-21 03:26 PM
Tlutrick
04-21-19 03:28 PM
socal72
SC- 1st Gen (1992-2000)
11-06-11 11:40 PM
nakman8
RX - 1st Gen (1999-2003)
12
09-08-11 10:23 AM
DroppedGS
GS - 1st Gen (1993-1997)
02-20-03 07:06 PM
Quick Reply: Cruise Control Problems
