1996 ls 400 iat sensor
Old 12-08-10, 10:51 AM
redtexan
redtexan's Avatar
Default 1996 ls 400 iat sensor
my car is pulling a code for the iat sensor but i can not find it on the car can somebody please point me in the right direction
Old 12-08-10, 11:57 AM
williamb82
williamb82's Avatar
its in the maf sensor. so if its bad, you have to change the whole maf
Old 12-08-10, 01:26 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
make sure the maf wiring is plugged in and not damaged....
Old 12-08-10, 01:41 PM
steve2006
steve2006's Avatar
IAT = Intake Air Temperature.
Old 12-08-10, 03:38 PM
redtexan
redtexan's Avatar
would the maf cause The car to idle good but when you give it gas it boggs down or is misfiring.When you accelerate you have no power but it will eventually get up to speed and it is sucking gas bad it smells like its running to rich. The catalytic converters (which are not clogged) are fire red after i drive it. What could it be my plugs and wires are good. Thank you for any input you could give me.
Old 12-08-10, 03:44 PM
PureDrifter
BahHumBug
Forum Moderator
yes .
Old 12-08-10, 03:49 PM
redtexan
redtexan's Avatar
Thank you
Old 12-26-10, 06:33 PM
Dtwillis5
Dtwillis5's Avatar
My car have the same problem. Do it run right after you change the mass air flow?
Old 08-16-19, 11:26 AM
webbjas7
webbjas7's Avatar
if it's fire red the cat is bad.
MurderedRx
03-23-17 08:42 PM
mitsuman
IS - 1st Gen (2001-2005)
07-28-16 03:02 PM
lexus-is2
03-26-13 07:12 PM
armanxpm
SC- 1st Gen (1992-2000)
02-24-10 11:04 PM
RedPhoenix
Performance & Maintenance
07-06-09 06:22 PM
Quick Reply: 1996 ls 400 iat sensor
