sub replacement for 97 ls400 nakamichi
Old 09-17-10, 02:19 AM
lexySC_909
lexySC_909's Avatar
Default sub replacement for 97 ls400 nakamichi
what's up guys. i just got a 97 ls400 with nakamichi and the sub is not working and i want to replace it with an aftermarket one. i been reading for about 3 days now and not sure if the sub is 8" or 10". i just want a sub that will replace the old nakamichi without adding an extra amp, but if i can't find one that will replace it, i am willing to add an amp. any ideas which subs will work with the stock nakamichi amp? i know that it needs a free-air sub, but not sure if i need a 5ohm or 2ohm one. 5ohm for nakamichi and 2ohm for the rest? how many watts? i know if i add an amp, i don't have to worry about the ohm, but for now, i want to just replace the sup without adding an amp.
Old 09-22-10, 09:21 PM
lexySC_909
lexySC_909's Avatar
any help? thanks
Old 09-23-10, 05:02 AM
williamb82
williamb82's Avatar
to use the stock amp it has to be 12ohm like the original. you can get yours re coned here
http://www.reconingspeakers.com/
iirc the nakamichi subs are 12ohm. it should state the ohm on the magnet of the one in your car now. have you checked it?
Old 10-07-10, 10:00 PM
lexySC_909
lexySC_909's Avatar
ok. so i fanilly got a chance to take a look at the sub. it is an 8 inch with 6 omh. any know if there is any sub will fit these specs? thanks
Chefao
SC400 / 300 Classifieds
05-25-13 03:13 PM
Blavatsky
03-03-09 11:23 AM
LiCelsior
09-14-07 05:00 PM
saelee39
12-30-05 12:37 AM
tkafam1
04-09-05 03:36 PM
Quick Reply: sub replacement for 97 ls400 nakamichi
