Tach quit after Throttle Body Cleaning
Old 06-19-10, 08:46 AM
dixiebuyer
dixiebuyer's Avatar
Default Tach quit after Throttle Body Cleaning
So my 96 ls threw a "left bank too rich" code the other day. I cleaned the throttle body and fixed the code. Now my tach doesn't work. Is this just a coincidence? Any ideas of what I might have done?
thanks in advance
Old 06-19-10, 11:19 AM
Thermactor
Thermactor's Avatar
bang on top of the dashboard like it owes you money
Old 06-19-10, 01:12 PM
dixiebuyer
dixiebuyer's Avatar
Default That was it.
Thanks, I guess it was just a coincidence. One sharp blow and the tach jumped.
Old 06-19-10, 01:23 PM
ls400rgr
ls400rgr's Avatar
My Tac and speedometer both will flat line for up to 5 minutes in the morning. then jump into action, other than feeding them coffee, has anyone experienced this on a '99 ls400? If so what was the fix
Old 06-20-10, 09:05 AM
20sburning
20sburning's Avatar
I have the exact same problem. No idea what the fix is. Mine is also a 99
Old 06-20-10, 09:31 AM
Sixdown
Sixdown's Avatar
Same thing and it's happened on every single one of my previous LS400's. Common problem with these gauge clusters.
Old 06-21-10, 01:16 PM
bravonext
bravonext's Avatar
Default Tach
so my 96 ls threw a "left bank too rich" code the other day. I cleaned the throttle body and fixed the code. Now my tach doesn't work. Is this just a coincidence? Any ideas of what i might have done?
Thanks in advance
thermactor writes the same thing everytime someone needs help with the tach or speedometer. I have a 1990 ls400 w/ 85k miles and the tach and speedometers move about 1/4 inch that's all. And appearently there is no remedy for it. I'm still waiting for a legit advice.
Old 06-21-10, 01:44 PM
Thermactor
Thermactor's Avatar
Hey, don't knock my advice. 60% of the time, it works every time
The real remedy? Send it to a professional repair place for bucks.
Old 06-25-10, 07:33 AM
greenrover
greenrover's Avatar
I don't know about the speedo but this is what I did for my lazy tachometer:
-open the gauge cluster and carefully grab the tach needle by its base
-pull outward until you feel or hear a little pop (or as much as you feel comfortable with)
-without letting go move the needle clockwise until you hear another light pop
-without letting go move the needle back to zero
-let go and it should stay there
-now move the needle up and let go, it should fall back to zero
This is what I did on mine and it has been working fine since (knock on wood).
Dukenukemx
RX - 1st Gen (1999-2003)
09-25-19 04:51 PM
isfvss
IS F (2008-2014)
17
06-06-17 06:46 PM
joeyfres
IS - 1st Gen (2001-2005)
12-05-16 06:43 AM
Kicktrip13
12-21-14 06:25 PM
hlu1
08-05-11 07:25 PM
Quick Reply: Tach quit after Throttle Body Cleaning
