A/C on engine temp rise // Need serious help! '00
Old 02-13-09, 09:27 AM
qewani1
qewani1's Avatar
Default A/C on engine temp rise // Need serious help! '00
After getting my LS400 back from a starter replacement operation, I had noticed that this fan is always working even if A/C is off... Is this a normal thing? Before this replacement it was working only while A/C is on.
http://i625.photobucket.com/albums/t...g?t=1234545742
Also I noticed that engine temperature gauge needle rise when I turn A/C on, btw engine coolant is full.
http://i625.photobucket.com/albums/t...g?t=1234545739
Please help!
Old 02-13-09, 05:35 PM
Lexozz
Lexozz's Avatar
I had the same problem on my '95. I corrected it by cleaning the radiator and condenser fins. They were clogged with debris over the years. As soon as I did that over heating was a thing of the past with the A/C on. I took a garden hose and sprayed from inside to out and you could see the lumps of dirt that was blocking the air flow.
Old 02-13-09, 05:37 PM
LiCelsior
Retired
LiCelsior's Avatar
yea but assuming he didnt have this problem before his starter job. you dont need to remove the radiator to do a starter job but just some coolant. but yes rinsing out your radiator will greatly improve its efficiency.
Old 02-14-09, 11:30 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
هلا اخوي... حي الله اهل الامارات....
did you double check all the connections?
Old 02-15-09, 03:57 AM
qewani1
qewani1's Avatar
ur nationality?
Any way today while coming back from work..i turned A/C and it seems ok , no overheating!
Old 02-15-09, 05:19 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by qewani1
ur nationality?
اخوك من السعوديه
if it comes and goes... it might be a bubble in the system? or do i have it the other way around?
Old 02-16-09, 05:00 AM
qewani1
qewani1's Avatar
ya this is what i got while googling for that.
It seems ok now.
Old 02-17-09, 04:28 PM
turbosix
turbosix's Avatar
the bolt on the top of the thermostat housing.... when the car is cold is used to burp pressure out of the system.
tsl95
04-13-19 12:47 PM
01-06-13 08:22 PM
LexSurfing
15
01-05-11 11:44 AM
TMaxxTim
Performance & Maintenance
39
05-04-06 09:43 PM
Lexicon1
SC- 1st Gen (1992-2000)
11-06-05 08:26 PM
Quick Reply: A/C on engine temp rise // Need serious help! '00
