Couple Q's, 91 1UZ
Old 01-15-09, 07:07 AM
TableSyrup
TableSyrup's Avatar
Default Couple Q's, 91 1UZ
Ok, so couple things.
This thing was front end impact on driverside.
So far:
New overflow container (Was leaking)
New used Washer fluid container (Still leaks need another one LOL)
New Plugs and Wires (RUNS FRIGGIN AWESOME!!!!!)
New windshield
Put her on the frame rack and pulled the strut tower down,forward, and into position, trams perfect now
To do:
New tires
Alignment
remove and replace top rail of core support (Cause of wrinkles n stuff)
replace driverside sngine plastics over plugs, front wire clip, rail left to right (cam pulley exposed)
check timing (Doesn't seem to be off, just worth checking)
change all fluids
hood, bumper cover, headlights, paint front clip
Q's:
So, I replaced the overflor cause it was leaking, so I'm sure there's a bunch of air in the system, the overflow appears to be the high point of the system and no bleeders anywhere, so:
Something is amiss cause it really fluctuates in how hot it'll blow. With temp set all the way up and on high, I vary probably 20+ degrees F, seems to pick up full tem at 2,000 RPM
Also, electrical system seems to lag until 2,000 RPM as well. Charging system untested but I'm pretty sure she's kickin cause the new battery is stayin charged and she cranks like she's tryin to flip the car over with the starter.
Anything there that raises a no brainer common issue? I realize it could be the alternator or regulator if there's an external one, just lookin for info, new to this engine n electrical setup.
Q's:
So this is supposed to have ABS, Traction, and steering control systems.... none of them work, and no indicators on the cluster.
The small fuse box located by the battery (At least that's where mine is, heh heh) is missing fuses/breakers/whatever.
Someone got a pic of it, and what each one is? These systems are most likely off cause of missing stuff in there. Still have to go through and check fuses and stuff.
Is there a diagram somewhere showing positions, functions, and values for all fuses/breakers and such?????
Thanx
BTW: Anyone got a link to a strut tower brace? With having racked the thing I think it's a good idea, regardless of all the gussets
Old 01-18-09, 11:42 AM
MEANDAFAKA
MEANDAFAKA's Avatar
try to post some picture, i wanna see what it looks like.
Old 01-18-09, 02:34 PM
TableSyrup
TableSyrup's Avatar
K thanx! I'll take em today or tomorrow, and post em tomorrow afternoon probably, super busy, gotta run
thank you!
Old 01-18-09, 03:15 PM
LiCelsior
Retired
LiCelsior's Avatar
www.lexls.com about coolant changing and how to get the air out of the system.
maybe your alternator is dying which might cause the electrical system to do that, also make sure terminals at tight. also make sure the power steering isnt leaking cuz that could mess it up.
ill snap a pic of the fuses later...or you could search for instant results.
93-98 MkIV SUPRA TURBO FSTB will fit and clear the 1uz no problem...search because there was a couple recent threads and i just picked mine up from a link given in the thread.
funcrusher
26
04-17-20 07:57 AM
NYGS300
06-26-16 01:19 AM
atlantis43
Maintenance
11-10-10 01:50 PM
kdumph
SC- 1st Gen (1992-2000)
26
03-17-08 07:09 AM
Quick Reply: Couple Q's, 91 1UZ
