Camshaft timing marks
Old 01-10-09, 12:18 PM
earnaldy
earnaldy's Avatar
Question Camshaft timing marks
I recently replaced the valve stem seals of my Lexus LS400 1995. Before I dismantled the camshafts I made my own marks setting the cramshaft at 0 BTC. I noticed that the timing marks between the inlet and exhaust camshaft gears are out for about 2 teeth in both sides of the motor. I checked the manual and it says that it should be on the marks.
I own this car from new and this is the first time the camshafts are dismantled. I mounted back the camshafts using my own marks and the car is running a little bit rough in low RPM, ( OBD scanner report a misfire in cylinder # 7) besides that everything is O.K. Somebody has a clue on this issue?
Best regards,
Eddie
lexusdog
10-17-13 11:39 AM
Lexinky
14
09-05-12 05:23 PM
cobalt91
05-16-12 05:42 AM
MJHSC400
Performance & Maintenance
02-11-07 12:31 PM
92lexus
02-26-03 10:29 AM
Quick Reply: Camshaft timing marks
