My driver window not working
Old 09-03-07, 11:19 PM
mrs.baam
mrs.baam's Avatar
Exclamation My driver window not working
Hello all I'm new here just need some help fixing a problem. My windows all of a sudden stopped working I thought its was my circuit breaker so i chaged it out with the circuit breaker for the power locks. It was working fine, now y driver side window won't go up or down all the others work from the driver side swtich except the driver window plz help.
Old 09-05-07, 04:09 PM
turbosix
turbosix's Avatar
open the door
push the switch all the way down for auto rolldown
now hit the leather of the door panel firmly with your fist
the window should roll down. you will have to pull it up while holding up on the button most likely.
get a new window motor :P
Old 08-09-08, 05:59 PM
MEANDAFAKA
MEANDAFAKA's Avatar
try that, didn't work for me
Old 08-10-08, 07:06 PM
Photoinc
Photoinc's Avatar
Had this problem on my 93 LS, it was the switch in the door. Took the door panel off and the switch assembly out. The driver window switch arched out soo much that it burned the contacts to the point that the window would not go up or down, it was actually stuck in the down position. I took the switches apart and sanded and cleaned the contacts, put back together, still going strong.
Total cost.....Zero
Old 01-28-11, 05:16 PM
joebob1
joebob1's Avatar
Total cost.....Zero
Thanks, I just did the same. My circuit board on the switch was all gummed up from 17 years of stuff falling in there. I cleaned it with some soap, water, and a toothbrush. I dried it and sanded the copper contact areas and it works for now.
Old 02-05-11, 07:07 PM
NjRican
NjRican's Avatar
I had this same problem. It was my window motor. But I would try cleaning the co facts first.
Old 02-06-11, 12:23 PM
Dtwillis5
Dtwillis5's Avatar
Before u change the motor check the window control by back window was doing that till I change the window control on the driver side
LS2k
06-25-23 06:59 AM
scarface85
04-05-21 04:41 PM
ccarruth
06-04-19 03:58 PM
mar1
03-28-12 05:07 AM
grindin8o8
SC- 1st Gen (1992-2000)
06-15-11 08:40 PM
Quick Reply: My driver window not working
