I think I found my parasitic electrical drain!!!!
Old 01-13-17, 03:53 AM
mckellyb
mckellyb's Avatar
Default I think I found my parasitic electrical drain!!!!
YAY!!!!!!!!!!!!!!!!!!!!!!
30 amp fuse, the one labeled "DC cut 1". There's about 1.5 amps going through that circuit for several minutes after closing the door (but not locking the car), then it eventually cycles between about 400 and 700 ma.
Now, to figure out what it is turning itself on/off and/or being the drain. Unfortunately, it appears that fuse is for a sub-panel of fuses inside. I shudder to think what some of those acronyms stand for.
I don't think there's another drain, either, because with that fuse pulled, the draw comes down to about 50 ma, and that's with the alarm armed.
Old 01-18-17, 09:40 AM
sktn77a
sktn77a's Avatar
Any update?
Old 01-23-17, 04:27 PM
mckellyb
mckellyb's Avatar
I'll know by Friday.
Old 01-28-17, 02:33 PM
is150
is150's Avatar
It's not a faulty door switch causing your power drain is it?
Old 01-29-17, 10:28 AM
mckellyb
mckellyb's Avatar
Here's what I'm 99.9% sure what it was.
I have an Ultragauge, which is a device that displays OBDII-sourced info. Miles, gallons used, engine temp (to a tenth of a degree until 200F), etc.
Well, I always leave it plugged in because the OBDII port should be 12V-free when the ignition is off.
Nope!!!
I'll know more in another week, but I've not had to put a charger on it since last weekend. Well, I did for a short period, at the 2A setting, while I had the ignition 'on' and flipping through the Techstream settings.
Old 03-15-18, 01:27 PM
Slickie
Slickie's Avatar
I realize this thread is over a year old,,,,,but would like to know:
Mckellyb, Have you finally resolved the issue with Parasitic battery drain ? and how did you do it?
Thanks,
Slews
Old 03-15-18, 01:31 PM
mckellyb
mckellyb's Avatar
See the post immediately before yours.
It was the Ultragauge.
Old 03-15-18, 02:41 PM
Slickie
Slickie's Avatar
Roger that Mckellyb. I guess I didn't capture your meaning there; My Bad.
I've got a 2008 LS460L that had the battery discharge on a 1 year old (Lexus 84 month) battery after the car sat for a week. And saw previous owner maintenance history with battery draining problem...So, I am just doing forum review on others that may have experienced the same.
Cheers,
S
Old 03-16-18, 03:51 AM
mckellyb
mckellyb's Avatar
No worries. Time to start pulling fuses with a meter hooked up to the battery. For joy.
Old 03-19-18, 10:56 AM
Slickie
Slickie's Avatar
Like life....its always something.
Toyboy300
08-05-24 04:11 PM
RobLambo
11-03-14 06:48 AM
HyadMusic
SC- 1st Gen (1992-2000)
06-15-14 01:52 PM
michaelw
GS - 1st Gen (1993-1997)
01-19-14 10:37 AM
DanielWin1
10-28-10 09:45 AM
Quick Reply: I think I found my parasitic electrical drain!!!!
