Right front wheel bearing
I replaced mine at 115,000 miles a few months ago...pretty strait forward, easy job. Well I had my car in the shop today and sure enough there was a little play in the right front wheel...the bearing is a little loose. The first time I replaced it was because of noise. But this one is now loose. I only have 8,000 miles on the bearing, it's a Beck Arnley I bought online for $160...do you think it's just a cheap bearing or do I have something going on? I figure it's probably just a cheap bearing, but we're talking about replacing two bearings in 3 months.
The one I just put in today is a Toyo...never heard of it, but it was quite a bit more money ($320).
Anyone else have any bearing problems? And has anyone ever heard of a situation that would cause one bearing to fail prematurely? Hopefully this is it for me as far as bearings go. I'm hoping Beck Arnley will give me some sort of credit on the part that just failed, especially if this is going to be a recurring thing.
I vote crappy aftermarket bearing. I hear stories from my friends of brand new but extremely crappy aftermarket parts they keep buying from Rockauto.
Also remember a lot of issues on the Acura board with certain aftermarket suspension parts failing after a year.
How much more is a brand new OEM bearing online from one of the websites I linked in a different thread?
I hate to hear about that, but I'm also glad you were able to detect the issue and fix it right away.
B/A, from what I understand, makes pretty good aftermarket parts. From research, I've also learned that, at one point in time, they were very reputable across the board, were as now, they have parts being made in different countries and therefore the quality varies.
These cars are quite heavy up front (as im sure you know)t and imagine a "less than adequate/faulty" bearing would show through in a short period of time.
How are those control arms holding up?
I cant recall which ones you replaced (the UCA's or LCA's), but im wondering if the set that you didn't replace have any "bearing" on the bearing (probably not, just a question).
Lastly, what symptoms were you experiencing that prompted you to take a look at your bearing?
The guy at the parts store told me the Toyo was OE, and the reason why it was so expensive, but when I got the box the back of it said Toyoda (which I thought was pretty hilarious). But I won't be laughing if I have to replace it next month. He did give me a three year warranty on it, so I figure I'm covered either way.
I'm thinking that B/A has to have a warranty on the part, perhaps 1yr/10 or 12k.
I wonder if they'll give me a credit? I'd rather that than have them send me a crappy wheel bearing that I already replaced with another brand.
Speaking of aftermarket parts, I replaced all my upper control arms and two lowers with aftermarket parts...so far so good. I checked the arms today and they look great. And I hope it stays that way because they were Beck Arnley
I'm with Rhambler. You really have to be careful with some of these aftermarket parts. They are often manufactured in China and there are no, as in zero, quality control considerations.
This has been a problem with airline parts, which is way more scarier.
I had a noticeable front noise(groaning) when going about 40 MPH, more prevalent on the drivers side. The dealer replaced both front wheel bearings., and it was covered under my CPO. They said they always replace both of them, as the wear is the same and the other one will probably be next. I think common practice is to replace both at the same time. As far as Beck/Arnley parts, I think they are good quality as I use them on my 650i BMW. I would see if Amazon will credit you for the bad unit. Good luck getting the part returned for credit.
Used to work in the aviation business an you are right nospinzone, aviation parts that are not approved is a big issue. The "SUPS", or Suspected Unapproved Parts are a big headache for the airlines and the FAA to control. Automotive parts do not have the scrutiny, so you do have to be careful who you buy from.
Engel
03-20-18 11:29 PM
dlamb89
31
02-15-16 05:44 AM
faithmkss
10-19-13 01:35 AM
