Lexus LS 460 front Parking Light
Hi, guys. I'm new to this forum.
I have a question about the front parking light, not the one on the side but the one closest to the grill that looks like a "nike" logo. The bulbs just burnt out and I'm planning to change it myself. What bulbs do I need and does anyone know the procedure to replace it? Thanks guys
I'm not sure if you're aware, but there is a search function at the top of the page as well as the sticky threads that have am abundance of information. In fact, there is a thread speaking to that specific topic. A very well outlined DIY.
Hope that helps and good luck.
More info under sticky but one of those thread is https://www.clublexus.com/forums/ls4...ment-pics.html
Last edited by jamodeo; 08-05-15 at 05:40 AM. Reason: Turned text link into clickable link
This is the same way I did mine, you must have long slim fingers with some muscles.
oh and i found these instructions to get to the bulb in another thread.
looks like you don't have to pull the bumper.
Originally Posted by Shibumi1 View Post
i did it without removing the whole bumper.. remove the grill (1) 10mm socket. the remove the plastic clips holding grille on each corner.then its easy as pulling the grille forward gently as u release the locking tabs (4).. once the grille is out you'll see a plastic trim w foam tucked behind the bumper trim on either side of the grille opening.bend it down then you'll see 2 wiring harnesses unclip them or bend the metal tabs holding them in place an you'll see the bulb socket reach in an turn it counterclockwise an pop the socket out.
Parking Lights/AKA Nike light
Just replaced my Parking lights with Led
T10 1.9w 6500K 171-Lumen 38-SMD LED
from deal extreme:
Warning, if you order from deal extreme, they do not give you a tracking number and it will take two - three weeks. depending on where you are located. Im in So Cal.
from deal extreme:
I now have this same problem. Change the front LED lights. I never did find the post that you were referred to for instructions to change the lights. I have a 2014 LS 460.
Will appreciate your help. Thanks Venny
fongaroos
02-15-02 01:45 AM
