Help! Where is TPMS sensor in LS 460?
Old 08-14-11, 04:09 PM
Mikey100
Mikey100's Avatar
Default LS460 correct pressures ?
In a normal 2008 LS460 system, what should the tire pressures be ?
Mine shows 5 different pressures. Should I set mine to all be the same ?
Lastly, can I use "regular" air from my large 60-gal air compressor, or do I need to use nitrogen ?
Thks for any help for this newbie.
Mikey
Old 08-14-11, 06:47 PM
rominl
exclusive matchup
rominl's Avatar
forget about nitogen, i think they are bs and you absolutely don't need it
i think 32/33psi on the 4 tires are good. for the spare, personally i will get it up to 45 just so it doesn't bother me as much when it leaks
Old 08-16-11, 09:58 AM
G-SharK
G-SharK's Avatar
With you on that "Rominl"
Old 08-22-11, 07:28 AM
eddie_k_
eddie_k_'s Avatar
I agree! The nitrogen thing is total BS!
Old 08-22-11, 01:01 PM
Nick2JZ
Nick2JZ's Avatar
eddie, so did you find a solution to the problem? I drive around town without the spare tire, and around 10mi. into driving the master warning light come on. I would like somehow to disable the spare tire TPMS.
Old 08-23-11, 09:31 AM
eddie_k_
eddie_k_'s Avatar
I am going with the wheel barrel wheel mod for now or until I can figure out how to disable or over ride.
The wheel barrel wheel mod is simply take out the TPMS sensors off the wheels drop them inside a wheel barrel wheel, fill it up to 30psi and leave it in the trunk with the spare.
Old 08-23-11, 11:44 AM
GammaLex
GammaLex's Avatar
Whats a wheel barrel? I havent had a chance to swap over my TPMS luckily my oem wheels are in the garage ive never had the flashing warning come on yet.
Old 08-24-11, 10:36 AM
eddie_k_
eddie_k_'s Avatar
This is a wheel barrel...
Old 08-24-11, 11:18 AM
GammaLex
GammaLex's Avatar
LOL I thought that was called a wheel barrow. I had no idea it was barrel. It must be a southern accent thing like earl and urnge lol for all the trouble of removing my tpms I would just put them on the new wheels.
Old 08-25-11, 04:43 PM
MikeE12345
MikeE12345's Avatar
See: http://en.wikipedia.org/wiki/Wheelbarrow
...Some people incorrectly substitute the word "barrel" in place of "barrow" as this seems to make more sense (possibly because the cavity in a wheelbarrow resembles a half-barrel). ...
Up here in the "north" we have never seen it spelled wheelbarrel!
Old 08-27-11, 04:56 PM
eddie_k_
eddie_k_'s Avatar
Either way, Back on the topic... I went this way until I figure out how to disable it.
Old 09-08-11, 08:01 AM
Sebastian9
Sebastian9's Avatar
Honda charges 110$ to reprogram TPMS so if you have winters/summers it'll ding you 220$ per year !
prichmon
05-07-19 02:31 PM
hks619
10-12-18 08:58 AM
girvan
07-31-09 09:34 PM
Bundy
12-18-07 03:04 AM
Quick Reply: Help! Where is TPMS sensor in LS 460?
