Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?
Old 01-01-17, 01:51 PM
ColdFusion
ColdFusion's Avatar
Default Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?
Hi, posting this for a friend here, as I don't own an LS.
My friend's trunk no longer closes/locks correctly, and after taking apart the entire trunk assembly we've deduced that the plastic rotating assembly (the one that rotates/locks the actual latch) is cracked and broken. The moving center piece with the arm no longer stays inside the plastic Y-shaped housing, and therefore when the motor actuates the trunk doesn't unlock.
Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?-s4qpstd.jpg
Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?-phntpzh.jpg
Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?-z4s1fuk.jpg
My question is, aside from buying the entire latch assembly (which is a mind blowing $350), does Lexus or anyone else sell JUST this plastic assembly, or even for that matter, the electrical wiring harness just for the latch? The rest of the latch works, it's just this plastic part that isn't, and from what I can tell, the electrical tongs are sandwiched between the plastic pieces. If that's not available, has anyone ever attempted to 3D scan/design/print a replacement part?
Thank you!
Old 01-01-17, 07:53 PM
sktn77a
sktn77a's Avatar
If you can find out who manufactures this unit and write to them, they might give you the part. I did this with my lumbar support and the company in Canada that makes it sent me the plastic gear that had disintegrated. Alternatively, see if you can find an LS at a breaker's yard and replace the unit.
Sherl (05-19-23)
Old 01-03-17, 06:17 AM
ColdFusion
ColdFusion's Avatar
How would I find that? Would it be printed on the part?
Old 01-03-17, 10:08 AM
sktn77a
sktn77a's Avatar
Google!
Old 05-18-23, 04:38 PM
99GS10LS
1st Gear
99GS10LS's Avatar
Default Any updates?
Anyone ever figure this out? The little plastic piece in the trunk lock actuator of my wife's car snapped in half. I'd love to not have to buy the entire actuator.
Old 05-19-23, 12:13 AM
jdanielca
jdanielca's Avatar
You can find these used cheap online or from rrr.lt
Sherl (05-19-23)
Boombai
12-03-17 06:03 AM
Kjames9951
12-13-14 02:00 PM
Z0SICK
10-22-13 06:49 PM
imherenow
12-13-12 12:13 PM
byroncat
09-20-11 07:04 PM
Quick Reply: Replacement for Plastic Lever Contraption for 2009 LS460 Trunk Release Mechanism?
