Confused - 2009 Ls460 DVD/Nav Update
Old 09-06-16, 08:16 AM
fooldall1
fooldall1's Avatar
Default Confused - 2009 Ls460 DVD/Nav Update
I have searched through 7 pages of search results regarding the 2009 LS460 DVD/NAV update.. Maybe my search terms are off, but am I understanding this correctly? There's no DIY for updating the 2009 LS460 Nav? In previous/other models, I recall putting in a DVD (in the glovebox).. hitting an "update" button in the NAV menu...voila.
I can't seem to find a clear answer on this question. is this something you *have* to have the dealer do? Again this is for a 2009 LS460.
Old 09-06-16, 08:41 AM
comotiger
comotiger's Avatar
I think the update has to be done by the dealer. Last year, they wanted $400 to update the maps on my previous car, a 2012 LS. I said no thanks, and used google maps instead.
Old 09-06-16, 08:45 AM
DarKnight
DarKnight's Avatar
Can only go through the dealer unless you have the equipment. Dealer was charging me a little over $200. You're better off putting that money towards the Gromaudio unit.
Old 09-06-16, 09:23 AM
fooldall1
fooldall1's Avatar
Augh, that SUCKS. Something so likely very simple.. made complicated. I get it if Lexus wanted to charge customers for the Map Update CD/DVD.. a lot of work goes into that. But then to not give the customers an easy way to update? Lame.
Old 09-06-16, 09:54 AM
Lynzoid
Lynzoid's Avatar
To update the 'new' navi (late 09+) you need a special kit AND a dvd. Not available to public AND expensive. The kit includes a special usb cable that plugs into the glovebox USB port and allows an upload to be performed.
OR you can extract the HDD from the navi headunit and perform a manual update. Search.
Old 09-06-16, 10:42 AM
fooldall1
fooldall1's Avatar
Does that somehow replace the integrated NAV? Looks kind of like a multi-input-to-aux device.
Old 09-06-16, 10:45 AM
fooldall1
fooldall1's Avatar
So- I will look in the Glovebox and see if there's a USB port. I'm not sure if mine is "late" 2009 or not. But after reading the Owner's Manual, it never mentioned a USB port. Assuming it's the OLDER system, is it still like the old LS430, where you take the CD/DVD tray out of the trunk and replace the disc? Or, is it actually a HDD? I will search those terms, so thanks for the guidance.
Old 09-06-16, 11:26 AM
DarKnight
DarKnight's Avatar
It's an aux input that will allow you to run apps. You're better off running google maps or waze instead of paying a few hundred for updates.
Old 09-06-16, 02:53 PM
roadfrog
roadfrog's Avatar
Hopefully it'll be available soon. Rumors swirling that it's delayed. I'd get it now if I could.
rominl
06-06-09 06:21 PM
fullmoon
11-23-08 12:54 AM
WhitBaby
05-16-08 05:47 PM
Mallory H.
02-12-07 11:24 AM
Quick Reply: Confused - 2009 Ls460 DVD/Nav Update
