Last edit by: IB Advertising
Browse all: Interior
- IS: How to Install Vaistech iPhone/Android Integration
Step by step instructions for do-it-yourself repairs
My Android Integration Demo Video with VAIS Technologies IVIC System
#46
I just sent a PM to CJITTY to inquire about what needs to be purchased in order for this to work.
Im a bit lost as to what version of the Samsung i'll have access to shortly, but its not the brand new one, but the one that was out about 6-8 months ago. Currently I have an HTC One that came out a few years ago-the original.
From what I understand, JITTY has an older phone and had a wired set-up.
Now has the same phone but is now wireless.
You, had a wired set-up, went wireless last month and, if I understand you correctly, liked the efficiency of the wired set-up vs the wireless set up?
Am I correct?
#47
I recently went to VAIS's website and it states that the 2007 LS460 is no longer supported due to lines on the screen since it is a Gen 5 Navigation System. I was very disappointed to say the least.
Anyone here have any luck getting this working on a 2007 LS460?
Thank you for your time in advance.
#48
Sorry for delay guys. I was one of the first folks on this forum to get the IVIC back in 2012. The first version is the IVIC 5D I believe is what it is called. I called them the other day and they said the current version would most likely work, but the reason they don't support it anymore is because of the vertical lines. So let me take you all step by step on how the vertical lines appear and how to resolve it (at least for me). My car is in for service and I'll come back and edit this post to include a video showing this.
Example:
1. Listening to XM Satellite Radio and your navigational map is on screen. IVIC is not running.
2. You want to know the artist of the song, so you hit the AUDIO button on left side of nave screen
3. You will be greeted with black screen and white vertical lines
4. Simply toggle your IVIC on by hitting the CD button until CD CHANGER 1 appears (which is IVIC input)
5. Let it get to the "Waiting for Andorid Screen"
6. Then go back to your XM source or previous source
7. Then click AUDIO..it will work as normal.
All of this can be done in less than 10 seconds and once you do the sequence, it's good for the entire time your car is on. It's a minor nuisance, but not a show stopper by any means. Full disclaimer, I have self parking feature, so I am not sure if this will work in a non self park version. Perhaps someone can try this method and confirm it works on NON SELF PARKING models.
I have skipped using the MHL adapter and using Chromecast. I have a legacy APK file for Chromecast that makes casting much easier than the new version. It works absolutely flawless for me and the best part about casting my screen wirelessly, is that I can keep my phone at 100% since the MHL adapter is not sucking the life out of my battery and decharging it quicker than it can charge. I use an OEM Samsung adaptive fast charger by the way. THe audio sounds great and I have no lag in audio when casting my screen. I am using a Galaxy Note 4, unrooted. No hacks. I also use a rotation screen app that forces landscape much better than IVIC Port app can do. In fact, I don't use ivic port app at all anymore. I have also NEVER performed a firmware upgrade on my IVIC. Firmware upgrades added no benefit to me, so I assumed to not mess up a good thing. Nearly 4 years later, I'm still happy with it. I only use my IVIC if I will be in my car more than 30 minutes or so. It's a process after all.
1. Activate IVIC by clicking DVD/CD button on head unit
2. Turn on my mobile hotspot (Chromecast needs wifi to work for ad-hoc sync)
3. Chromecast will connect to my hotspot automatically within 5 seconds or less
4. Open Chromecast app
5. Click CastScreen
6. Open SiriusXM app, select my channel
7. Open WAZE or Google Maps app for my navigation
8. Use Force Rotation App to make every app landscape
9. Make sure phone has charging cable to keep battery high
10.. Put car in Drive and go.
All of this takes less than 30 seconds, but still..I don't do all of this for quick trips..not that serious. I also have slim bluetooth mouse to drive my screen..it works far better than the IVIC touch screen. My IVIC is not bluetooth connected to my phone either with my Chromecast...just creates lag and I don't use the navigation touchscreen, just my mouse. I hope this update helps someone..
Here are some demo vids on my IG account for how I am using chromecast to wirelessly cast to IVIC
https://www.instagram.com/p/869qTamicw/
https://www.instagram.com/p/76nCV9mide/
Example:
5. Click CastScreen
#49
2007 Lexus LS460 IVIC-5DR installed and working
I took the chance and ordered a IVIC-5DR and installed in my 2007 Lexus LS460. The company said the cables would connect but they did not support it and it may or may not work! Well after a few hours and installing the box inside the console... all done and Working!!!!
I would like to have a larger menu tho.... maybe its a setting? the home screen is only in the center of the NAV screen.... I have the IVIC app and running as you see....
I must be missing something????
#51
Does your car have self park? I couldn't watch the video at work but does your back up camera still work or did you lose it's functionality?
#52
#55
No dumb questions here macjac! Yes, that's what self-park is. Park ASSIST is where you have sensors in the bumpers and a back up camera (usually).
#56
Thought so. So I only have park assist. Matter of fact I'm asking these ?'s because I was interested in buying your ivic but I didn't know if the problems with the screen and the stripes and bars issue could be actually corrected with the Cjitty fix since no one chimed in that has a car with just park assist.
#57
I recommend going the Chromecast route and not do the MHL HDMI out...see if it works better by casting the screen. The ivic is funny about phone formats, but using Chromecast, any phone that can cast screen using Chromecast app "should" work.
#59
Congrats on the install. How hard was it getting to the back of nav and radio to plug it all in? I saw the youtube video, but haven't tried getting back there to install other stuff.
It was not bad at all.... the video helped out tremendously -Helping me not breaking any tabs etc.... I am using the MHL adapter and its usb powered also so it does charge the phone... I ran everything into my glove -wires, IVIC etc... all hidden... So far this was well worth the $300 I paid for it! Bought it off someone on Amazon..
I did figure out my backscreen size issue... the photo that was my background photo was taken in portrait mode (upright) instead of landscape mode (holding the phone sideways)...easy fix!!!
Does the chrome cast use your tether on your phone to work??
#60
Yes I set up my phones mobile hot spot to connect the chromecast to it. So when I turn on my hotspot, my chromecast would see it and then I could cast screen to it and I was off and running
